After enabling CAPsMAN wifi stops working
RB4011iGS+5HacQ2HnD router Firmware 7.21.1.
I’m trying to add another router to extend wifi. Actually my setup worked until I made something stupid and had to setup router again…
Now When I enable CAP in Wireless/Wireless window, Wifi interfaces are marked with Managed by CAPsMAN, but in
Wireless/CAPsMAN menu no Radios exist, also no CAP interface and wifi is not working.
If I plug in router that I use to extend wifi range (RB4011iGS+5HacQ2HnD-IN)  2 radios appear and that part of wifi is working. But main router wifi is down…
What am I to do?
My Config:
#2026-01-26 20:50:34 by RouterOS 7.21.1
#software id = BTUP-35GF
#model = RB4011iGS+5HacQ2HnD
#serial number = removed by mod
add admin-mac=F4:1E:57:61:A0:9F auto-mac=no comment=defconf name=bridge
set [ find default-name=ether1 ] mac-address=6C:3B:6B:DF:31:F4 name=ether-wan
/interface wireless
#managed by CAPsMAN
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX
distance=indoors frequency=auto mode=ap-bridge ssid=MikroTik
wireless-protocol=802.11
#managed by CAPsMAN
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=
20/40/80mhz-XXXX distance=indoors frequency=auto mode=ap-bridge ssid=
MikroTik wireless-protocol=802.11
/caps-man security
add authentication-types=wpa-psk,wpa2-psk encryption=aes-ccm
group-encryption=aes-ccm name=security_PP
/caps-man configuration
add channel.band=2ghz-b/g/n .control-channel-width=20mhz .extension-channel=
XX country=slovenia datapath.client-to-client-forwarding=yes
.local-forwarding=yes mode=ap name=cfg-2ghz security=security_PP ssid=
MikroTikXX
add channel.band=5ghz-a/n/ac .control-channel-width=20mhz .extension-channel=
XXXX country=slovenia datapath.client-to-client-forwarding=yes
.local-forwarding=yes mode=ap name=cfg-5ghz-ac security=security_PP ssid=
MikroTikXX
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk comment=
defconf disable-pmkid=yes mode=dynamic-keys supplicant-identity=MikroTikXX
add address-pool=default-dhcp interface=bridge name=defconf
/caps-man manager
set enabled=yes
/caps-man provisioning
add action=create-dynamic-enabled master-configuration=cfg-2ghz name-format=
prefix-identity name-prefix=2ghz
add action=create-dynamic-enabled master-configuration=cfg-5ghz-ac
name-format=prefix-identity name-prefix=5ghz-ac
/disk settings
set auto-media-interface=bridge auto-media-sharing=yes auto-smb-sharing=yes
add bridge=bridge comment=defconf interface=ether6
add bridge=bridge comment=defconf interface=ether7
add bridge=bridge comment=defconf interface=ether8
add bridge=bridge comment=defconf interface=ether9
add bridge=bridge comment=defconf interface=ether10
add bridge=bridge comment=defconf interface=sfp-sfpplus1
add bridge=bridge comment=defconf interface=wlan2
/interface detect-internet
set detect-interface-list=all
add comment=defconf interface=ether-wan list=WAN
/interface wifi cap
set caps-man-addresses=127.0.0.1 discovery-interfaces=wlan1,wlan2 enabled=yes
/interface wifi capsman
set enabled=yes interfaces=wlan1,wlan2 require-peer-certificate=no
/interface wireless cap
set bridge=bridge caps-man-addresses=127.0.0.1 enabled=yes interfaces=
wlan1,wlan2
add address=192.168.88.1/24 comment=defconf interface=bridge network=
192.168.88.0
/ip dhcp-client
add interface=ether-wan
/ip dhcp-server lease
add address=192.168.88.180 client-id=1:90:9:d0:4:67:dc mac-address=
90:09:D0:04:67:DC server=defconf
add address=192.168.88.157 client-id=1:dc:a6:32:52:3b:e9 mac-address=
DC:A6:32:52:3B:E9 server=defconf
add address=192.168.88.160 client-id=1:0:11:32:49:76:ec mac-address=
00:11:32:49:76:EC server=defconf
add address=192.168.88.171 client-id=1:40:f8:df:c6:3:31 mac-address=
40:F8:DF:C6:03:31 server=defconf
add address=192.168.88.0/24 comment=defconf dns-server=192.168.88.1 gateway=
192.168.88.1
set allow-remote-requests=yes
/ip dns adlist
add ssl-verify=no url= Some url (works)
add address=192.168.88.1 comment=defconf name=router.lan type=A
add action=accept chain=forward comment="defconf: accept in ipsec policy"
ipsec-policy=in,ipsec
add action=accept chain=forward comment="defconf: accept out ipsec policy"
ipsec-policy=out,ipsec
add action=fasttrack-connection chain=forward comment="defconf: fasttrack"
"defconf: accept established,related, untracked" connection-state=
established,related,untracked
add action=drop chain=forward comment="defconf: drop invalid"
connection-state=invalid
"defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat
in-interface-list=WAN
add action=accept chain=input connection-state=established
add action=accept chain=input connection-state=related
add action=drop chain=input in-interface-list=!LAN
add action=masquerade chain=srcnat comment="defconf: masquerade"
add action=dst-nat chain=dstnat comment=NAS_WEB dst-port=80 in-interface=
all-ethernet protocol=tcp to-addresses=192.168.88.180 to-ports=80
add disabled=yes dst-address=0.0.0.0/0 gateway=xx.xx.xxx.x
/ip service
set ftp disabled=yes
set ssh disabled=yes
set telnet disabled=yes
set www disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/ipv6 firewall address-list
/ipv6 firewall filter
add action=accept chain=input comment=
"defconf: accept established,related,untracked" connection-state=
add action=drop chain=input comment="defconf: drop invalid" connection-state=
invalid
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute"
dst-port=33434-33534 protocol=udp
"defconf: accept DHCPv6-Client prefix delegation." dst-port=546 protocol=
udp src-address=fe80::/10
add action=accept chain=input comment="defconf: accept IKE" dst-port=500,4500
protocol=udp
add action=accept chain=input comment="defconf: accept ipsec AH" protocol=
ipsec-ah
add action=accept chain=input comment="defconf: accept ipsec ESP" protocol=
ipsec-esp
"defconf: drop everything else not coming from LAN" in-interface-list=
!LAN
add action=fasttrack-connection chain=forward comment="defconf: fasttrack6"
add action=drop chain=forward comment="defconf: rfc4890 drop hop-limit=1"
add action=accept chain=forward comment="defconf: accept ICMPv6" protocol=
icmpv6
add action=accept chain=forward comment="defconf: accept IKE" dst-port=
500,4500 protocol=udp
add action=accept chain=forward comment="defconf: accept ipsec AH" protocol=
ipsec-ah
add action=accept chain=forward comment="defconf: accept ipsec ESP" protocol=
ipsec-esp
!LAN
/system clock
set time-zone-name=Europe/Lol
/system identity
set name=MikroTik-Router
/system routerboard settings
set enter-setup-on=delete-key
/tool mac-server
/tool mac-server mac-winbox
Please reformat you post using < / > (Preformatted text) button.
Reading it on the phone takes ages due to scrolling.
What packages do you have installed on the main router and the extra AP router? It looks like you might have a mix of old wireless and new wifi config.
Check in System, Packages. For each device, please provide a list of what you have installed.
@BartoszP meant to use the tag like this:
So main router RB4011iGS+5HacQ2HnD has only 2 packages: Routeros 7.21.1 and wireless 7.21.1
and additional router set as CAP RB4011iGS+5HacQ2HnD-IN has many packages under routeros-arm and wireless is 6.49.19
