Sorry, I’ve missed your reply @raimondsp. Here is the output (masked public IPs)
/interface export hide-sensitive
# aug/08/2022 07:33:36 by RouterOS 7.4
# model = CCR2216-1G-12XS-2XQ
add admin-mac=02:4A:B4:F6:2D:A4 auto-mac=no ingress-filtering=no name=bridge-LAN vlan-filtering=yes
add name=bridge-Loopback
set [ find default-name=ether1 ] l2mtu=1584 name=ether-Management
set [ find default-name=qsfp28-1-1 ] auto-negotiation=no fec-mode=off name=qsfp28-1-1-Spine-1 speed=25Gbps
set [ find default-name=qsfp28-1-2 ] auto-negotiation=no fec-mode=off name=qsfp28-1-2-Spine-1 speed=25Gbps
set [ find default-name=qsfp28-1-3 ] auto-negotiation=no fec-mode=off name=qsfp28-1-3-Spine-2 speed=25Gbps
set [ find default-name=qsfp28-1-4 ] auto-negotiation=no fec-mode=off name=qsfp28-1-4-Spine-2 speed=25Gbps
set [ find default-name=qsfp28-2-1 ] auto-negotiation=no fec-mode=off name=qsfp28-2-1-Spine-1 speed=25Gbps
set [ find default-name=qsfp28-2-2 ] auto-negotiation=no fec-mode=off name=qsfp28-2-2-Spine-1 speed=25Gbps
set [ find default-name=qsfp28-2-3 ] auto-negotiation=no fec-mode=off name=qsfp28-2-3-Spine-2 speed=25Gbps
set [ find default-name=qsfp28-2-4 ] auto-negotiation=no fec-mode=off name=qsfp28-2-4-Spine-2 speed=25Gbps
set [ find default-name=sfp28-1 ] auto-negotiation=no name=sfp28-1-HostFiber speed=10Gbps
set [ find default-name=sfp28-2 ] auto-negotiation=no name=sfp28-2-HostFiber speed=10Gbps
set [ find default-name=sfp28-3 ] auto-negotiation=no name=sfp28-3-Azure-1 speed=25Gbps
set [ find default-name=sfp28-4 ] auto-negotiation=no name=sfp28-4-Azure-2 speed=25Gbps
set [ find default-name=sfp28-5 ] auto-negotiation=no name=sfp28-5-Azure-1 speed=25Gbps
set [ find default-name=sfp28-6 ] auto-negotiation=no name=sfp28-6-Azure-2 speed=25Gbps
set [ find default-name=sfp28-7 ] auto-negotiation=no name=sfp28-7-MacPro speed=10Gbps
set [ find default-name=sfp28-8 ] auto-negotiation=no name=sfp28-8-MacPro speed=10Gbps
set [ find default-name=sfp28-9 ] auto-negotiation=no name=sfp28-9-iDRAC speed=10Gbps
set [ find default-name=sfp28-10 ] auto-negotiation=no name=sfp28-10-iDRAC speed=10Gbps
set [ find default-name=sfp28-11 ] auto-negotiation=no name=sfp28-11-Guto speed=10Gbps
set [ find default-name=sfp28-12 ] auto-negotiation=no name=sfp28-12-Vivo
/interface pppoe-client
add disabled=no interface=sfp28-12-Vivo name=pppoe-Vivo profile=profile-Vivo user=cliente@cliente
/interface vlan
add interface=bridge-LAN name=vlan20-Guest vlan-id=20
add interface=bridge-LAN name=vlan30-Doors vlan-id=30
add interface=bridge-LAN name=vlan31-IoT vlan-id=31
add interface=bridge-LAN name=vlan40-Staff vlan-id=40
add interface=bridge-LAN name=vlan50-UniFi vlan-id=50
add interface=bridge-LAN name=vlan80-iDRAC vlan-id=80
add interface=bridge-LAN name=vlan90-Management vlan-id=90
add interface=bridge-LAN name=vlan100-Servers vlan-id=100
/interface bonding
add mode=802.3ad name=bond-HostFiber slaves=sfp28-1-HostFiber,sfp28-2-HostFiber transmit-hash-policy=layer-2-and-3
add mode=802.3ad name=bond-MacPro slaves=sfp28-7-MacPro,sfp28-8-MacPro transmit-hash-policy=layer-2-and-3
add mode=802.3ad name=bond-Spine-1 slaves=qsfp28-1-1-Spine-1,qsfp28-1-2-Spine-1,qsfp28-2-1-Spine-1,qsfp28-2-2-Spine-1 \
add mode=802.3ad name=bond-Spine-2 slaves=qsfp28-1-3-Spine-2,qsfp28-1-4-Spine-2,qsfp28-2-3-Spine-2,qsfp28-2-4-Spine-2 \
add mode=802.3ad name=bond-iDRAC slaves=sfp28-10-iDRAC,sfp28-9-iDRAC transmit-hash-policy=layer-2-and-3
/interface vlan
add interface=bond-HostFiber name=vlan-HostFiber-AWS-993 vlan-id=993
add interface=bond-HostFiber name=vlan-HostFiber-Azure-1-995 vlan-id=995
add interface=bond-HostFiber name=vlan-HostFiber-Azure-2-1011 vlan-id=1011
add interface=bond-HostFiber name=vlan-HostFiber-IP-2836 vlan-id=2836
/interface ethernet switch
set 0 l3-hw-offloading=yes name=switch-chip
set 8 l3-hw-offloading=no
set 9 l3-hw-offloading=no
set 19 l3-hw-offloading=no
add name=WAN
add name=FastTrack
add bridge=bridge-LAN interface=bond-Spine-1
add bridge=bridge-LAN interface=bond-Spine-2
add bridge=bridge-LAN ingress-filtering=no interface=bond-MacPro pvid=100
add bridge=bridge-LAN interface=bond-iDRAC
add bridge=bridge-LAN interface=sfp28-11-Guto
add bridge=bridge-LAN interface=sfp28-3-Azure-1 pvid=100
add bridge=bridge-LAN interface=sfp28-4-Azure-2 pvid=100
add bridge=bridge-LAN interface=sfp28-5-Azure-1 pvid=100
add bridge=bridge-LAN interface=sfp28-6-Azure-2 pvid=100
/interface bridge vlan
add bridge=bridge-LAN tagged=bond-Spine-1,bond-Spine-2,bridge-LAN vlan-ids=20
add bridge=bridge-LAN tagged=bond-Spine-1,bond-Spine-2,bridge-LAN vlan-ids=30
add bridge=bridge-LAN tagged=bond-Spine-1,bond-Spine-2,bridge-LAN vlan-ids=31
add bridge=bridge-LAN tagged=bond-Spine-1,bond-Spine-2,bridge-LAN vlan-ids=40
add bridge=bridge-LAN tagged=bond-Spine-1,bond-Spine-2,bridge-LAN vlan-ids=50
add bridge=bridge-LAN tagged=bridge-LAN,bond-iDRAC vlan-ids=80
add bridge=bridge-LAN tagged=bond-Spine-1,bond-Spine-2,bridge-LAN vlan-ids=90
add bridge=bridge-LAN tagged=bond-Spine-1,bond-Spine-2,bridge-LAN untagged=\
sfp28-3-Azure-1,sfp28-4-Azure-2,sfp28-5-Azure-1,sfp28-6-Azure-2,bond-MacPro vlan-ids=100
add bridge=bridge-LAN untagged=bridge-LAN,sfp28-11-Guto vlan-ids=1
add interface=pppoe-Vivo list=WAN
add interface=vlan-HostFiber-IP-2836 list=WAN
/interface ovpn-server server
set auth=sha1,md5
/ip export hide-sensitive
# aug/08/2022 07:37:00 by RouterOS 7.4
# software id = 7KAG-BQDH
/ip dhcp-server option
add code=119 name=domain-search value=0x0b7069706173747564696f7303636f6d00
/ip dhcp-server option sets
add name=dhcp-options options=domain-search
/ip ipsec policy group
add name=group-Staff-VPN
/ip ipsec profile
add dh-group=modp2048,modp1536,modp1024 dpd-interval=disable-dpd enc-algorithm=aes-256,aes-192,aes-128 hash-algorithm=sha256 name=profile-Staff-VPN
/ip ipsec peer
add exchange-mode=ike2 name=peer-Staff-VPN-HostFiber passive=yes profile=profile-Staff-VPN send-initial-contact=no
/ip ipsec proposal
add auth-algorithms=sha512,sha256,sha1 enc-algorithms=aes-256-cbc,aes-256-ctr,aes-256-gcm,aes-192-ctr,aes-192-gcm,aes-128-cbc,aes-128-ctr,aes-128-gcm lifetime=8h name=proposal-Staff-VPN \
pfs-group=none
add name=pool-Staff-VPN ranges=10.41.0.2-10.41.0.254
add name=pool-Doors ranges=10.30.0.54-10.30.0.254
add name=pool-Guest ranges=10.20.0.54-10.20.0.254
add name=pool-IoT ranges=10.31.0.54-10.31.0.254
add name=pool-LAN ranges=10.10.0.54-10.10.0.254
add name=pool-Staff ranges=10.40.0.54-10.40.255.254
add name=pool-UniFi ranges=10.50.0.150-10.50.0.254
add add-arp=yes address-pool=pool-Doors dhcp-option-set=dhcp-options interface=vlan30-Doors lease-time=1d name=dhcp-Doors
add add-arp=yes address-pool=pool-Guest interface=vlan20-Guest name=dhcp-Guest
add add-arp=yes address-pool=pool-IoT dhcp-option-set=dhcp-options interface=vlan31-IoT lease-time=1d name=dhcp-IoT
add add-arp=yes address-pool=pool-LAN dhcp-option-set=dhcp-options interface=bridge-LAN lease-time=1d name=dhcp-LAN
add add-arp=yes address-pool=pool-Staff dhcp-option-set=dhcp-options interface=vlan40-Staff lease-time=1d name=dhcp-Staff
add add-arp=yes address-pool=pool-UniFi dhcp-option-set=dhcp-options interface=vlan50-UniFi lease-time=1d name=dhcp-UniFi
/ip ipsec mode-config
add address-pool=pool-Staff-VPN address-prefix-length=32 name=modeconfig-Staff-VPN split-dns="pipastudios.com,adf.azure.com,blob.core.windows.net,database.windows.net,web.core.windows.ne\
t,privatelink.web.core.windows.net,privatelink.blob.core.windows.net,privatelink.database.windows.net" split-include=10.0.0.0/8 static-dns=10.100.90.10,10.200.1.10 system-dns=no
add address=10.41.0.1/24 interface=bridge-Loopback network=10.41.0.0
add address=169.254.248.26/30 comment="AWS DirectConnect" interface=vlan-HostFiber-AWS-993 network=169.254.248.24
add address=192.168.100.129/30 comment="Azure Express Route" interface=vlan-HostFiber-Azure-1-995 network=192.168.100.128
add address=192.168.100.133/30 interface=vlan-HostFiber-Azure-2-1011 network=192.168.100.132
add address=1.2.3.165/26 comment="HostFiber IP" disabled=yes interface=vlan-HostFiber-IP-2836 network=1.2.3.128
add address=1.2.3.166/26 disabled=yes interface=vlan-HostFiber-IP-2836 network=1.2.3.128
add address=1.2.3.171/26 disabled=yes interface=vlan-HostFiber-IP-2836 network=1.2.3.128
add address=1.2.3.177/26 interface=vlan-HostFiber-IP-2836 network=1.2.3.128
add address=10.10.0.1/24 interface=bridge-LAN network=10.10.0.0
add address=10.20.0.1/24 interface=vlan20-Guest network=10.20.0.0
add address=10.30.0.1/24 interface=vlan30-Doors network=10.30.0.0
add address=10.31.0.1/24 interface=vlan31-IoT network=10.31.0.0
add address=10.40.0.1/16 interface=vlan40-Staff network=10.40.0.0
add address=10.50.0.1/24 interface=vlan50-UniFi network=10.50.0.0
add address=10.100.80.1/24 interface=vlan80-iDRAC network=10.100.80.0
add address=10.100.90.1/24 interface=vlan90-Management network=10.100.90.0
add address=10.100.100.1/24 interface=vlan100-Servers network=10.100.100.0
add address=10.100.110.1/24 interface=vlan100-Servers network=10.100.110.0
/ip dhcp-server lease
add address=10.40.244.192 client-id=1:0:d7:6d:59:f7:a4 mac-address=00:D7:6D:59:F7:A4 server=dhcp-Staff
add address=10.10.0.0/24 dhcp-option-set=dhcp-options dns-server=10.100.90.10,10.200.1.10 domain=pipastudios.com gateway=10.10.0.1
add address=10.20.0.0/24 dns-server=10.100.90.10,8.8.8.8,1.1.1.1 gateway=10.20.0.1
add address=10.30.0.0/24 dhcp-option-set=dhcp-options dns-server=10.100.90.10,10.200.1.10 domain=pipastudios.com gateway=10.30.0.1
add address=10.31.0.0/24 dhcp-option-set=dhcp-options dns-server=10.100.90.10,10.200.1.10 domain=pipastudios.com gateway=10.31.0.1
add address=10.40.0.0/16 dhcp-option-set=dhcp-options dns-server=10.100.90.10,10.200.1.10 domain=pipastudios.com gateway=10.40.0.1
add address=10.50.0.0/24 dhcp-option-set=dhcp-options dns-server=10.100.90.10,10.200.1.10 domain=pipastudios.com gateway=10.50.0.1
set servers=8.8.8.8,1.1.1.1
/ip firewall address-list
add address=10.10.0.0/24 list=bgp-Networks
add address=10.41.0.0/24 list=bgp-Networks
add address=10.100.90.0/24 list=bgp-Networks
add address=10.100.100.0/24 list=bgp-Networks
add address=10.40.0.0/16 list=bgp-Networks
add address=10.100.110.0/24 list=bgp-Networks
add address=10.100.80.0/24 list=bgp-Networks
add address=1.2.3.177 list=vpn-IPs
add address=4.5.6.77 list=vpn-IPs
add address=10.40.0.3 list=printers
add action=passthrough chain=forward comment=IN in-interface-list=WAN
add action=passthrough chain=forward comment=OUT out-interface-list=WAN
add action=passthrough chain=forward comment="IN / OUT"
add action=drop chain=forward comment="Drop dumb" src-address=10.40.244.192
add action=drop chain=input src-address=10.40.244.192
add action=drop chain=output src-address=10.40.244.192
add action=fasttrack-connection chain=forward comment=FastTrack connection-state=established,related hw-offload=yes
add action=accept chain=forward connection-state=established,related
add action=drop chain=input comment="Drop DNS Requests" dst-port=53 in-interface-list=WAN protocol=tcp
add action=drop chain=input dst-port=53 in-interface-list=WAN protocol=udp
add action=drop chain=forward comment="Drop Guest" disabled=yes dst-address-list=printers src-address=10.20.0.0/24
add action=accept chain=input comment=Winbox dst-port=8223 in-interface=all-vlan protocol=tcp
add action=accept chain=input dst-port=8223 in-interface-list=WAN protocol=tcp
add action=accept chain=input comment="Established / Related" connection-state=established,related
add action=accept chain=input comment=IPSec dst-address-list=vpn-IPs dst-port=4500,500 protocol=udp
add action=accept chain=input dst-address-list=vpn-IPs protocol=ipsec-esp
add action=drop chain=input comment="Drop invalid" connection-state=invalid
add action=drop chain=input comment="-- DROP ALL --" in-interface-list=WAN
add action=src-nat chain=srcnat disabled=yes out-interface=vlan-HostFiber-IP-2836 to-addresses=1.2.3.165
add action=src-nat chain=srcnat disabled=yes out-interface=pppoe-Vivo to-addresses=4.5.6.77
add action=dst-nat chain=dstnat comment="iPerf3 Internet Test" disabled=yes dst-port=959 protocol=tcp to-addresses=10.10.0.240
add action=accept chain=srcnat ipsec-policy=out,ipsec
/ip ipsec identity
add auth-method=eap-radius certificate="Pipa VPN,GoDaddy,GoDaddy_1,GoDaddy_2" generate-policy=port-strict mode-config=modeconfig-Staff-VPN peer=peer-Staff-VPN-HostFiber \
policy-template-group=group-Staff-VPN
/ip ipsec policy
add dst-address=10.0.0.0/8 group=group-Staff-VPN proposal=proposal-Staff-VPN src-address=0.0.0.0/0 template=yes
add check-gateway=ping disabled=no distance=2 dst-address=0.0.0.0/0 gateway=1.1.1.1 routing-table=main scope=30 suppress-hw-offload=no target-scope=11
add comment="HostFiber monitor" disabled=no distance=1 dst-address=8.8.8.8/32 gateway=1.2.3.129 pref-src="" routing-table=main scope=10 suppress-hw-offload=no target-scope=10
add check-gateway=ping disabled=no distance=1 dst-address=0.0.0.0/0 gateway=8.8.8.8 pref-src="" routing-table=main scope=30 suppress-hw-offload=no target-scope=11
add comment="Vivo monitor" dst-address=1.1.1.1 gateway=4.5.6.49 scope=10
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh port=8222
set api disabled=yes
set winbox port=8223
set api-ssl disabled=yes
