After mark routing enabled, VPN user can't see LAN pc's
Hello
RB3011UiAS
os: 6.46.1
My configuration with LAN + WAN and VPN is working correctly
now i add wan2 with mark routing
and when the VPN user is connected, he can’t see any comuter on LAN, but internet is working fine.
If someone can tell my what i made wrong.
thank you
add action=masquerade chain=srcnat out-interface=ether10 src-address=\
192.168.0.0/22
out-interface=ether1 src-address=192.168.0.0/22
add action=masquerade chain=srcnat comment="masq. vpn traffic" src-address=\
192.168.89.0/24
Mark routing
/ip firewall address-list
add address=192.168.1.3 list=Use_WAN1
add address=192.168.1.7 list=Use_WAN1
add address=192.168.1.11 list=Use_WAN1
add address=192.168.0.0/22 list=Use_WAN2
add address=192.168.89.0/24 list=Use_WAN2 comment=VPN
/ip firewall mangle
add action=mark-routing chain=prerouting comment="Use WAN1" disabled=no log=no log-prefix="" new-routing-mark=To_WAN1 passthrough=no src-address-list=Use_WAN1
add action=mark-routing chain=prerouting comment="Use WAN2" disabled=no log=no log-prefix="" new-routing-mark=To_WAN2 passthrough=no src-address-list=Use_WAN2
add action=masquerade chain=srcnat disabled=no log=no log-prefix="" out-interface=ether1 src-address=192.168.0.0/22
add action=masquerade chain=srcnat disabled=no log=no log-prefix="" out-interface=ether10 src-address=192.168.0.0/22
add distance=1 gateway=18x.xxx.xxx.xxx routing-mark=To_WAN1
add distance=1 gateway=192.168.40.1 routing-mark=To_WAN2
The thing is that if a packet has got a routing-mark, and a route whose dst-address matches the packet’s destination address and whose routing-mark matches the one attached to the packet exists, that route is used. Since you only have the default route via the WAN’s gateway marked with To_WAN2, and you attach the routing-mark To_WAN2 to all packets matching the respective src-address-list no matter what their destination is, even packets for your connected subnets are sent out via WAN2 because no routes to local subnets marked with To_WAN2 exist.
There are several ways to deal with this:
  1. prevent packets for any local subnets from getting the routing-mark by adding dst-address-list=!local-subnets to the action=mark-routing rules (and populate the address list with the necessary rows), maybe it is enough to use dst-address=!192.168.0.0/16 instead.
  2. use /ip route rule add dst-address=192.168.0.0/16 action=lookup-only-in-table table=main to override the routing-mark assigned by the action=mark-routing rules for destination subnets (but you may actually need several rules depending on your network topology, you cannot use address lists in /ip route rule)
  3. add routes to local subnets with routing-mark=To_WAN2
I try the first one and its working fine.
thank you
just a question, why not 192.168.0.0/22 but muss be /16??
thank you
It was just an example in the absence of information about your overall network topology. If all your subnets which are not reachable via the WANs fit into 192.168.0.0/22, that one is of course sufficient.
