After reboot make loop of long signal, hhd connect to usb
Mikrotik hap ac with Router OS 6.36.3
when connect hdd and reboot he can’t start up he make long signal.
When i disconnect hdd, all ok boot normal.
what can i do?
Is that USB HDD externally powered? If not, try with a powered USB hub, most probably the Hap cannot power the HDD.
no man, it has power adaptor, its 1T size have DC 5V/2A power adaptor. Silicon Power WiFi Hard Drive H10 i use usb connection disable wifi.
and can’t understand what happening?
Try using a USB hub.
