Heloo!
After restart device the PPP (3G) connection is not established.
I have RB 411U f-v: 5.2 and inside 3G modem (mPCIE-E Option GTM 380).
After configuration PPP clients everything works correct. Connection is made.
My configuration PPP (before restart):
[admin@MikroTik] /interface ppp-client> print
0 R name="era" max-mtu=1500 max-mru=1500 mrru=disabled port=usb2 data-channel=2
info-channel=2 apn="eradata" pin="" user="" password="" profile=default
phone="*99#" dial-command="ATDT" modem-init="" null-modem=no
dial-on-demand=no add-default-route=yes use-peer-dns=yes
keepalive-timeout=30 allow=pap,chap,mschap1,mschap2
My configuration ports (before restart):
[admin@MikroTik] > port print
Flags: I - inactive
# NAME CHANNELS USED-BY BAUD-RATE
0 serial0 1 Serial Console auto
1 usb2 3 PPP <era> 9600
When I do restar device, the connection is not established.
the log shows me:
“initializing”
“waiting for packets…”
“terminating… - could not acquire serial port”
“disconnected”
My logs after restart:
[admin@MikroTik] > log print
01:00:17 system,error,critical router was rebooted without proper shutdown
01:00:25 async,ppp,info era: initializing...
01:00:25 async,ppp,info era: reseting link...
01:00:25 async,ppp,info era: reseting link... - could not acquire serial port
01:00:25 async,ppp,info era: disconnected
01:00:26 async,ppp,info era: initializing...
01:00:26 async,ppp,info era: reseting link...
01:00:26 async,ppp,info era: reseting link... - could not acquire serial port
01:00:26 async,ppp,info era: disconnected
01:00:27 async,ppp,info era: reseting link... - could not acquire serial port
01:00:27 async,ppp,info era: disconnected
01:00:27 interface,info ether1 link up (speed 100M, full duplex)
01:00:28 async,ppp,info era: initializing...
01:00:28 async,ppp,info era: reseting link...
01:00:28 async,ppp,info era: reseting link... - could not acquire serial port
01:00:28 async,ppp,info era: disconnected
01:00:31 async,ppp,info era: initializing...
01:00:31 async,ppp,info era: reseting link...
01:00:31 async,ppp,info era: reseting link... - could not acquire serial port
01:00:31 async,ppp,info era: disconnected
01:00:38 async,ppp,info era: initializing...
01:00:38 async,ppp,info era: reseting link...
01:00:38 async,ppp,info era: reseting link... - could not acquire serial port
01:00:38 async,ppp,info era: disconnected
01:00:48 async,ppp,info era: initializing...
01:00:48 async,ppp,info era: reseting link...
01:00:48 async,ppp,info era: reseting link... - could not acquire serial port
01:00:48 async,ppp,info era: disconnected
01:00:57 system,info,account user admin logged in from 192.168.2.5 via winbox
01:00:58 async,ppp,info era: initializing...
01:00:58 async,ppp,info era: reseting link...
01:00:58 async,ppp,info era: reseting link... - could not acquire serial port
01:00:58 async,ppp,info era: disconnected
01:01:08 system,info,account user admin logged in from 192.168.2.5 via telnet
01:01:08 async,ppp,info era: initializing...
01:01:08 async,ppp,info era: reseting link...
01:01:08 async,ppp,info era: reseting link... - could not acquire serial port
01:01:08 async,ppp,info era: disconnected
01:01:18 async,ppp,info era: initializing...
01:01:18 async,ppp,info era: reseting link...
01:01:18 async,ppp,info era: reseting link... - could not acquire serial port
01:01:18 async,ppp,info era: disconnected
My configuration PPP (after restart):
0 name="era" max-mtu=1500 max-mru=1500 mrru=disabled port=usb2 data-channel=2 info-channel=2 apn="eradata" pin="" user="" password="" profile=default phone="*99#"
dial-command="ATDT" modem-init="" null-modem=no dial-on-demand=no add-default-route=yes use-peer-dns=yes keepalive-timeout=30 allow=pap,chap,mschap1,mschap2
My configuration ports (after restart):
Flags: I - inactive
1 usb2 2 9600
After Restart RB all settings PPP seems correct ( the same before restart), I can see the difference in the ports configuraftions.
What to do to get rid of the problem?
export-before-restart.txt (14.3 KB)
export-after-restart.txt (14.3 KB)
Please help Me.
Paul
