Dhcp Relay is working fantastically on fixed ehternet connections but not on the wlan connections. It worked fine before the upgrade to v6.40.4.
What additional settings are required on the wlan connections to allow a DHCP Relay to work on WLAN connections?
Problem solved. After upgrade device switched from bridge to router.
I was puzzled why the ethernet connections worked, but those are switched not bridged.
