I have recently bought CCR2004 with 7.1 soft. I have Configured ipsec Site-Site tunnel according to instruction on many sites. Tunnel was established between CCR2004 soft 7.1 and RB3011 soft 6.49.1)
eg. https://www.informaticar.net/how-to-establish-site-to-site-vpn-with-mikrotik-routers/
Tunnel is established but there is not transfer between sites. Of course there is a rule in NAT (in the first place) that accepts packets form sites not to go through NAT.
I put the same configuration to router RB4011 with soft 6.49.1. Tunnel is established between RB4011 (6.49.1) and RB3011 (6.49.1). Everything is working OK communication between sites is working OK.
After upgrade RB4011 from 6.49.1 to 7.1 communication stopped working. No packed are transferred through IPSEC Tunnel. Tunnel itself is established, but no packet between sites are going…
Is there anything special that should I setup on 7.1 soft or this is just a bug of 7.1 soft (I have tried 7.1 rc7, but the problem persists). I don’t have access to older soft from 7 version…
My configuration of IPSEC tunnel is simple:
IPSEC Configuration RB4011/CCR2004 v7.1 OS
LAN IP SRC RB4011/CCR2004 v7.1 OS: 192.168.10.1/24
LAN IP RB3011 (Poznan) v6.49.1 OS: 192.168.29.1/24
In my situation after reboot nothing changed tunnels where established but no transfer between them.
Maybe my test was on 28 tunnels…But with 6.49 everything was OK. Only soft upgrade to 7.1 and everything fall down.
support@mikrotik also have already Christmas.
Sorry but waiting 2 weeks for the answer that they products doesn’t work (CCR with obligatory OS 7) is something that is not right.
For me the tunnel was working but I experience massive packet drops. WIreshark showed a lot of TCP DUPs and Retransmissions. After changing the underlay from IPSec to WireGuard it is smooth now. On top I have a GRE tunnel with OSPF. No DUPs and Retransmissions now.
I’ve tested 7.x version few days ago , there was a lot of problem with it, such as routing tunnels and so on.
Seriously I suggest all of you not to test 7.x version in production environments just use stable versions.
+1 Confirming this problem.
IPSEC tunnel and connections to remote computers via RDP works while on 6.49.1.
After upgrading to 7.1 IPSEC tunnel is established without errors, but I am unable to access remote resources. In IPSEC “Active peers” tab there are zero Rx Bytes/packets.
Tunnel works ok with 3des, Tunnel encryption should not have influence to routing. I have some old routers on the other side and I need to use 3des instead aes-128
We had the same issue on RB1100AHx4 after upgrade from v6.49.2->v7.1.1.. IPSec VPN tunnel is estableshed fine but packets weren’t routed to the tunnel. RDC to a client host stopped working after the upgrade.
Had to downgrade to v6. Found several bugs while the downgrade. All of the found bugs were related with IP\Firewall\Mangle fields mapping.
More details. We use 2 WANs and so have several IP\Firewall\mangle settings. While the downgrade I faced with field mapping bugs. [New] Connection mark and [New] Routing mark fields were filled incorrectly. I even lost connection to the office network and had to ask collegues to help. I’m not ready to check on production router but I propose there is the same bug with field mapping while upgrading V6->V7. And that may be the reason why the routing fails.
Same problems here. http/https sessions are not working. icmp does go through the tunnel
I haven’t been able to get my hex-s working again. Rollback to 6.49 didn’t fix the issue, even after a clean wipe with netinstall.
It’s driving me crazy
