after upgrade to 6.3 cannot generate certificate-request
ther error is: failure: failed to write private key file
is true! i have the same issue:
on 6.3:
[admin@MikroTik] /certificate> create-certificate-request
template:
Script Error: action cancelled
on 6.1
key-passphrase:
on 6.3 request a template¿?
M
+1
template:
I have following error on ROS 6.4:
/certificate> create-certificate-request challenge-passphrase=foobar key-passphrase=f00b4r template=foobar
Hi all,
i have tried to create certificates :
[Mikrotik] / create-certificate-request
template:
have you change the procedure ?
Best Regards,
Daniel
Same here.
Guess I need to find another way.
-Louis
I have same problem.
Can someone frorm mikrotik confirm that this is a known bug?
I also get this problem on 6.4
[admin@MikroTik] > certificate create-certificate-request
template:
hello everybody!
i have the same problem on 6.4:
[admin@router0500000] > certificate create-certificate-request
template: router0500000
key-passphrase: ******
challenge-passphrase: ******
have somebody solve this problem?
Will be fixed in v6.5
How do I work around this on RouterOS 6.4?
Can I simply create a certificate request somewhere else, and import certificate, key and bundle to the RB?
I have the same issue with v6.5
Hello I just installed 6.5v . System keeps giving the same when I try to setup SSL certificate. Template:
Script Error
Because you need to make template and use it when generating request.
How to make it? Any tutorial, please?
/certificate template add …
How about some documentation?
/certificate template> add
failure: At least one field specifying certificate name must be set!
Not a particularly helpful response.
[admin@MikroTik] /certificate template add
with ROS 6.5 i’m now able to generate a certificate request and a key … but importing a certificate is not possible. fix one but break another is not very helpful. this situation is worse as before when we had to generate a request somewhere else and import the key+cert. i’m wondering whether mikrotik developers are using unit-tests to ensure everything works as expected.
