After VPN, no internal access
I did a VPN on mikrotik that sends all traffic through the tunnel.
When the tunnel is up, the local machines could not access Mikrotik administration.
I tried through web, ssh and winbox.
How can I do to access the mikrotik locally, with the tunnel running?
Francisco
you have VPN through the router you want to access, that is not in same ethernet as you are? most probably you have to add additional specific route to your router so you can access it. See manual of respective OS how to add additional route.
