Again... VLAN on the Rb750Gr3
Hello all,
Warning: ROS Noob here. Please be patient. Help me to learn and understand.
I'm having some trouble setting up VLAN on the Rb750Gr3. I read that one must use software-bases VLAN, since the switch chip does not support. But I am not 100% how this is done. Please enlighten me. I already read through the forums, but haven't found anything that would help me solve this yet. Please forgive if I missed something.
Here is what I want to achieve:
Port 5 shall be connected to a VLAN-aware switch and there shall be several VLANs on that switch. I started with vlan-home, which shall also be used for untagged traffic.
Here is my config:
jun/10/2018 10:35:42 by RouterOS 6.42.3
model = RouterBOARD 750G r3
add name=bridge
add fast-forward=no name=bridge-ether5 pvid=10 vlan-filtering=yes
/interface vlan
add interface=bridge-ether5 name=vlan-home vlan-id=10
set 0 default-vlan-id=2
set 1 default-vlan-id=2
set 2 default-vlan-id=2
set 3 default-vlan-id=2
set 4 default-vlan-id=10
set 5 default-vlan-id=2
add comment=defconf name=WAN
add comment=defconf name=LAN
/ip hotspot profile
add name=dhcp_pool2 ranges=10.0.0.2-10.0.0.254
add address-pool=default-dhcp disabled=no interface=bridge name=defconf
add address-pool=dhcp_pool2 disabled=no interface=vlan-home name=dhcp1
add bridge=bridge interface=ether2 pvid=2
add bridge=bridge interface=ether3 pvid=2
add bridge=bridge interface=ether4 pvid=2
add bridge=bridge-ether5 interface=ether5 pvid=10
/interface bridge vlan
add bridge=bridge-ether5 untagged=vlan-home vlan-ids=10
add interface=ether1 list=WAN
add address=192.168.88.1/24 comment=defconf interface=bridge network=192.168.88.0
add address=10.0.0.1/24 interface=vlan-home network=10.0.0.0
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid disabled=no interface=ether1
add address=10.0.0.0/24 gateway=10.0.0.1
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 name=router.lan
/system clock
set time-zone-name=Europe/Vienna
/system routerboard settings
set silent-boot=no
/tool mac-server
/tool mac-server mac-winbox
I have a rasperry pi connected to port5 to test if vlan-home and the DHCP server are working, but it doesn't. The Pi will not get an IP and with manual setup I am not able to ping the router. I would assume, that untagged traffic also goes to vlan-home and it should work...
Hi, reset the configs and try this.
  1. Create bridge.
  2. Add ether5 to bridge
  3. /Interface bridge port ether5->vlan set frame-types to vlan tagged only and enable ingress-filtering (don’t change the port pvid)
  4. Create vlan 10 in /interface bridge vlan, tagged ports are the bridge and ether5, no untagged ports
  5. Create vlan in /Interface, set the interface for the Vlan to be the bridge and pvid 10.
  6. Set ip address and dhcp on Vlan10 interface.
  7. Enable bridge vlan-filtering.
If no other ports will take part in the VLAN’s on RB750, then it should be very simple.
All you will need is a trunk port between vlan aware switch and router, to do this, do the following:
Make port 5 on router stand alone, i.e. not part of bridge.
Create all required VLAN’s under /interface vlan and assign them to port 5.
Create / assign IP and DHCP to the vlan interfaces
Configure access between VLAN’s on firewall
Connect router port 5 to switch trunk port
Thank you CZFan, that did work out the way you described it.
