Hi Masters
I have configured VPN using MT PPTP Client.I have created PPTP-Client and i am connected to the VPN server.
Now the senario is mentioned below.
MT Client.
WAN IP . 128.0.0.99.with Internet.
LAN IP . 151.151.151.1/24
Now thru PPTP client i am connected to VPN server and i am getting the IP address from DHCP (VPN Server).
I am not able to ping the network behind VPN serverfrom my local machin (151 series). I am able to ping it from MT Client.
Pl help me which route i hve to add.
You need to setup a route on your MT client from your Local IP address range to a remote PPTP server. Also make sure you have Proxy-ARP enabled.
Sir,
I am NOt getting u. Please explain me how to Do that. Wer to enable the Proxy-ARP
Ashish.
Enable proxy-arp on the LAN side of the PPTP server side. Then setup a ip address on that interface (example: 10.0.1.1/28). Then on your pptp client side give your private side the ip address 10.0.1.2/28. Then make a route from 10.0.1.2 to 10.0.1.1.
So, I have to add 151. series network at my PPTP VPN server side.
Correct and then make a route to that ip address assigned on PPTP server on the PPTP client.
