Hi guys,
I noticed when agent is set to default - i wait long time for popup on dude map. Also double clicking device takes long time to open. If I change from default to server - all is much faster.
I have only one agent - and that one is server - that means server is default - but still change gives much better performance (few ms instead of 2-3 seconds)
Amen to that post.
In the dude, Opening a device settings would take a long time when the Agent is set to “default”!!!
Now if i set that Agent to “server”, wow, there is no delay at all !!!
No overall performance issues noticed other that mentioned above. I believe it can be fixed
Above problem applies for dude versions 6.38.1 to 6.39.41
Can you please fix the root cause, and if there is a way to change this setting for all devices one time.
