Aggregate power radio
Hi Mikrotik people!
I have a question about power of MIMO radios.
When I see in datasheet 22dBm power and 24dBm (2chains) → aggregate power.. this value how is calculate?
If I use two chain I can reach distance like a 24dBm radio no MIMO?
every antenna will have 22dbm so 22dbm+22dbm=25dbm, not 24dbm, so if you use only one antenna you will have only 22dbm.
Sorry.. Only I write an example.. sorry for incorrect example..
The output power is 22+22=25 and there is de final output power.. I can reach distance with this radio like a radio with 1 chain and 25dBm??
Thanks inoX!!
