Hi guys, It’s my first post here.
I need to use an CISCO AIRONET 1232 AG as RB951 wireless repeater, but I have a problem when try to associate the AIRONET with RB951.
When the Aironet connects to RB951, after 5 seconds, recibe the message “Disconnect, Unicast key exchange time out”
Both AP are configured with WPA2 and CCM cipher.
The Aironet is configured as REPEATER, and configured the SSID and PASSWORD of RB951.
The RB951 is configured as AP-BRIDGE, SSID and PASSOWRD, WPA2 and CCPM Cipher.
Maybe is a compatibility problem, because the Aironet is more old than RB951, but I don’t know.
Attach Mikrotik and Aironet Configuration.
Best regards and thanks for your help.
Mikrotik Conf
0 name="wlan1" mtu=1500 l2mtu=1600 mac-address=6C:3B:6B:5A:AB:7B arp=enabled interface-type=Atheros AR9300 mode=ap-bridge ssid="home" frequency=2442 band=2ghz-onlyg channel-width=20mhz secondary-channel=""
scan-list=default wireless-protocol=unspecified vlan-mode=no-tag vlan-id=1 wds-mode=disabled wds-default-bridge=none wds-ignore-ssid=no bridge-mode=enabled default-authentication=yes default-forwarding=yes
default-ap-tx-limit=0 default-client-tx-limit=0 hide-ssid=no security-profile=default compression=no
Aironet Conf
Building configuration...
Current configuration : 2349 bytes
version 12.3
no service pad
service timestamps debug datetime msec
service timestamps log datetime msec
service password-encryption
hostname Aironet
enable secret 5 $1$cGgL$Vad/nxvAxCsdffdsYkl1xSUE1
clock timezone GMT -3
ip subnet-zero
no aaa new-model
dot11 ssid home
max-associations 50
authentication open
authentication key-management wpa
infrastructure-ssid
wpa-psk ascii 7 0112100149180F0E25455800170404
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption mode ciphers aes-ccm
ssid home
short-slot-time
parent timeout 10
speed basic-1.0 basic-2.0 basic-5.5 basic-6.0 basic-9.0 basic-11.0 basic-12.0 basic-18.0 basic-24.0 basic-36.0 basic-48.0 basic-54.0
rts retries 10
packet retries 15
station-role repeater
antenna gain 5
no dot11 extension aironet
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
shutdown
speed basic-6.0 9.0 basic-12.0 18.0 basic-24.0 36.0 48.0 54.0
station-role root
bridge-group 1
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
interface BVI1
ip address 192.168.10.251 255.255.255.0
no ip route-cache
ip default-gateway 192.168.10.254
no http server
no ip http secure-server
bridge 1 route ip
