I am trying to solve why Airplay and Sonos traffic won’t work across two SSIDs on the same access points. Everything else works fine. This manifests as being unable to connect my iPhone to play something on my Sonos speakers.
Wireless network = 3 TP-Link EAP773 access points, connected via cables to a Zyxel Switch. There are 2 SSIDs associated with the APs
The Zyxel switch is connected by an SFP+ DAC to my RB5009 router
The router is connected to the internet.
TP-Link has confirmed that there is no reason why this traffic shouldn’t route across the SSIDs. Connecting the APs to the Mikrotik router does not change anything. If the phone and Sonos device are connected to the same SSID everything works like a charm.
I think I’ve ruled out the APs. Is something in the config likely to be getting in the way? How can I troubleshoot this? Could it be something to do with my pi-hole container running on the RB5009?
# 2025-10-08 13:24:28 by RouterOS 7.20
# software id = 4SAD-K293
# model = RB5009UG+S+
# serial number = HE408Z9RT61
add name="Local Bridge" port-cost-mode=short
add name=dockers port-cost-mode=short
set [ find default-name=ether1 ] name="Port 1 - Study"
set [ find default-name=ether2 ] name="Port 2 - Living Room"
set [ find default-name=ether3 ] name="Port 3 - Girl's Room"
set [ find default-name=ether4 ] name="Port 4 - Snug"
set [ find default-name=ether5 ] name="Port 5 - VH Backup"
set [ find default-name=ether6 ] name="Port 6"
set [ find default-name=ether7 ] name="Port 7 - Kitchen"
set [ find default-name=ether8 ] mac-address=A4:43:8C:36:0B:B1 name=\
"Port 8 - WAN"
set [ find default-name=sfp-sfpplus1 ] name="Port 9 - SFP+"
/interface veth
add address=172.17.0.2/24,fd6c:b6e2:f488::2/64 dhcp=no gateway=172.17.0.1 \
gateway6=fd6c:b6e2:f488:: mac-address=44:4F:16:BE:02:9D name=veth1
/interface wireguard
add listen-port=13231 mtu=1420 name=wireguard1
/container mounts
add dst=/etc/dnsmasq.d name=dnsmasq_pihole src=\
/usb1-part1/pihole/etc-dnsmasq.d
add dst=/etc/pihole name=etc_pihole src=/usb1-part1/pihole/etc
/disk
add parent=usb1 partition-number=1 partition-offset=512 partition-size=\
128035675648 type=partition
add name=listBridge
add name=WAN
add comment=defconf include=listBridge name=LAN
add name=TRUSTED
/ip ipsec mode-config
add connection-mark=ipsec name=NordVPN responder=no
/ip ipsec policy group
add name=NordVPN
/ip ipsec profile
add dpd-interval=2m dpd-maximum-failures=5 name=NordVPN
/ip ipsec peer
add address=al55.nordvpn.com comment=Albania exchange-mode=ike2 name=NordVPN \
profile=NordVPN
/ip ipsec proposal
add name=NordVPN pfs-group=none
add name=dhcp_pool0 ranges=10.160.100.20-10.160.100.200
add address-pool=dhcp_pool0 interface="Local Bridge" lease-time=10m name=\
dhcp1
/ip smb users
add name=Darren
/ipv6 pool
add name=IPv6_dockers prefix=fd6c:b6e2:f488::/48 prefix-length=64
/caps-man manager
set enabled=yes
/container
add envlists=pihole_envs interface=veth1 logging=yes mounts=\
dnsmasq_pihole,etc_pihole name=Pi_Hole remote-image=pihole/pihole:latest \
root-dir=usb1-part1/pihole start-on-boot=yes workdir=/
/container config
set registry-url=https://registry-1.docker.io tmpdir=usb1-part1/pull
/container envs
add key=DNSMASQ_USER list=pihole_envs value=root
add key=FTLCONF_webserver_api_password list=pihole_envs value=Ham1sh01
add key=TZ list=pihole_envs value=Europe/London
/ip smb
set domain=WORKGROUP enabled=yes interfaces="Local Bridge"
add bridge="Local Bridge" interface="Port 2 - Living Room" \
internal-path-cost=10 path-cost=10
add bridge="Local Bridge" interface="Port 1 - Study" internal-path-cost=10 \
path-cost=10
add bridge="Local Bridge" interface="Port 7 - Kitchen" internal-path-cost=10 \
path-cost=10
add bridge="Local Bridge" interface=*F internal-path-cost=10 path-cost=10
add bridge="Local Bridge" interface="Port 3 - Girl's Room" \
add bridge="Local Bridge" interface="Port 4 - Snug" internal-path-cost=10 \
path-cost=10
add bridge=dockers interface=veth1 internal-path-cost=10 path-cost=10
add bridge="Local Bridge" interface="Port 6"
add bridge="Local Bridge" interface="Port 5 - VH Backup"
add bridge="Local Bridge" interface="Port 9 - SFP+"
set udp-timeout=10s
set discover-interface-list=TRUSTED
add interface="Local Bridge" list=listBridge
add interface="Port 8 - WAN" list=WAN
add interface=dockers list=listBridge
add interface=wireguard1 list=listBridge
add interface="Local Bridge" list=LAN
add interface=dockers list=LAN
add interface=wireguard1 list=LAN
add interface="Local Bridge" list=TRUSTED
add interface=wireguard1 list=TRUSTED
/interface ovpn-server server
add mac-address=FE:A8:27:88:84:9C name=ovpn-server1
/interface wireguard peers
add allowed-address=192.168.10.2/32 comment="2 iPhone" interface=wireguard1 \
name=peer5 public-key=""
add allowed-address=192.168.10.4/32 comment="4 Dell XPS13 Darren" interface=\
wireguard1 name=peer7 public-key=\
add allowed-address=192.168.10.5/32 comment="5 iPad" interface=wireguard1 \
name=peer8 public-key=""
add allowed-address=192.168.10.11/32 interface=wireguard1 name=peer1 \
public-key=""
add address=10.160.100.1/24 interface="Local Bridge" network=10.160.100.0
add address=192.168.10.1/24 comment=WireGuard1 interface=wireguard1 network=\
192.168.10.0
add address=172.17.0.1/24 comment="Docker container address range" interface=\
dockers network=172.17.0.0
/ip cloud
set ddns-enabled=yes ddns-update-interval=10m
/ip dhcp-client
/ip dhcp-server lease
add address=10.160.100.68 client-id=1:ec:71:db:2e:8c:e0 mac-address=\
EC:71:DB:2E:8C:E0 server=dhcp1
add address=10.160.100.150 client-id=1:f8:25:51:b6:4a:bc mac-address=\
F8:25:51:B6:4A:BC server=dhcp1
add address=10.160.100.93 client-id=1:5a:63:f6:f3:6d:11 mac-address=\
5A:63:F6:F3:6D:11 server=dhcp1
add address=10.160.100.97 client-id=1:d8:5e:d3:a6:37:14 mac-address=\
D8:5E:D3:A6:37:14 server=dhcp1
add address=10.160.100.30 client-id=1:0:11:32:b7:b2:15 mac-address=\
00:11:32:B7:B2:15 server=dhcp1
add address=10.160.100.75 client-id=\
30:3a:31:3a:31:3a:36:63:3a:31:66:3a:66:37:3a:34:30:3a:34:62:3a:64:38 \
mac-address=6C:1F:F7:40:4B:D8 server=dhcp1
add address=10.160.100.152 client-id=1:70:49:a2:21:4a:9 mac-address=\
70:49:A2:21:4A:09 server=dhcp1
add address=10.160.100.0/24 dns-server=10.160.100.1 gateway=10.160.100.1
set allow-remote-requests=yes cache-size=8192KiB max-concurrent-queries=1000 \
max-concurrent-tcp-sessions=2000 servers=\
1.1.1.3,1.0.0.3,2606:4700:4700::1113,2606:4700:4700::1003 use-doh-server=\
https://family.cloudflare-dns.com/dns-query verify-doh-cert=yes
/ip dns static
add address=104.16.249.249 name=cloudflare-dns.com type=A
add address=104.16.248.249 name=cloudflare-dns.com type=A
/ip firewall address-list
add address=0.0.0.0/8 comment=RFC6890 list=not_in_internet
add address=172.16.0.0/12 comment=RFC6890 list=not_in_internet
add address=192.168.0.0/16 comment=RFC6890 list=not_in_internet
add address=10.0.0.0/8 comment=RFC6890 list=not_in_internet
add address=169.254.0.0/16 comment=RFC6890 list=not_in_internet
add address=127.0.0.0/8 comment=RFC6890 list=not_in_internet
add address=224.0.0.0/4 comment=Multicast list=not_in_internet
add address=198.18.0.0/15 comment=RFC6890 list=not_in_internet
add address=192.0.0.0/24 comment=RFC6890 list=not_in_internet
add address=192.0.2.0/24 comment=RFC6890 list=not_in_internet
add address=198.51.100.0/24 comment=RFC6890 list=not_in_internet
add address=203.0.113.0/24 comment=RFC6890 list=not_in_internet
add address=100.64.0.0/10 comment=RFC6890 list=not_in_internet
add address=240.0.0.0/4 comment=RFC6890 list=not_in_internet
add address=192.88.99.0/24 comment="6to4 relay Anycast [RFC 3068]" list=\
not_in_internet
add address=telegraph.co.uk list=VPN
add address=4.78.139.50 list=YouTube
add address=4.78.139.54 list=YouTube
add address=23.101.24.70 list=YouTube
add address=23.202.231.167 list=YouTube
add address=23.217.138.108 list=YouTube
add address=23.225.141.210 list=YouTube
add address=23.234.30.58 list=YouTube
add address=31.13.64.7 list=YouTube
add address=31.13.67.19 list=YouTube
add address=31.13.67.33 list=YouTube
add address=31.13.67.41 list=YouTube
add address=31.13.68.169 list=YouTube
add address=31.13.69.169 list=YouTube
add address=31.13.69.245 list=YouTube
add address=31.13.70.9 list=YouTube
add address=31.13.70.13 list=YouTube
add address=31.13.70.33 list=YouTube
add address=31.13.71.19 list=YouTube
add address=31.13.73.9 list=YouTube
add address=31.13.73.169 list=YouTube
add address=31.13.75.5 list=YouTube
add address=31.13.75.12 list=YouTube
add address=31.13.76.65 list=YouTube
add address=31.13.76.99 list=YouTube
add address=31.13.80.37 list=YouTube
add address=31.13.80.54 list=YouTube
add address=31.13.80.169 list=YouTube
add address=31.13.81.4 list=YouTube
add address=31.13.82.33 list=YouTube
add address=31.13.82.169 list=YouTube
add address=31.13.83.2 list=YouTube
add address=31.13.83.34 list=YouTube
add address=31.13.84.2 list=YouTube
add address=31.13.84.34 list=YouTube
add address=31.13.85.2 list=YouTube
add address=31.13.85.34 list=YouTube
add address=31.13.85.53 list=YouTube
add address=31.13.85.169 list=YouTube
add address=31.13.86.21 list=YouTube
add address=31.13.87.9 list=YouTube
add address=31.13.87.19 list=YouTube
add address=31.13.87.33 list=YouTube
add address=31.13.87.34 list=YouTube
add address=31.13.88.26 list=YouTube
add address=31.13.88.169 list=YouTube
add address=31.13.90.19 list=YouTube
add address=31.13.90.33 list=YouTube
add address=31.13.91.6 list=YouTube
add address=31.13.91.33 list=YouTube
add address=31.13.92.5 list=YouTube
add address=31.13.94.7 list=YouTube
add address=31.13.94.10 list=YouTube
add address=31.13.94.23 list=YouTube
add address=31.13.94.36 list=YouTube
add address=31.13.94.37 list=YouTube
add address=31.13.94.41 list=YouTube
add address=31.13.94.49 list=YouTube
add address=31.13.95.17 list=YouTube
add address=31.13.95.18 list=YouTube
add address=31.13.95.33 list=YouTube
add address=31.13.95.34 list=YouTube
add address=31.13.95.35 list=YouTube
add address=31.13.95.37 list=YouTube
add address=31.13.95.38 list=YouTube
add address=31.13.95.48 list=YouTube
add address=31.13.95.169 list=YouTube
add address=31.13.96.192 list=YouTube
add address=31.13.96.193 list=YouTube
add address=31.13.96.194 list=YouTube
add address=31.13.96.195 list=YouTube
add address=31.13.96.208 list=YouTube
add address=10.160.100.97 comment="admin local desktop" list=Authorized
add address=10.160.100.69 comment="admin Dell XPS 13 laptop" list=Authorized
add address=10.160.100.93 comment="admin Dell iPad" list=Authorized
add address=10.160.100.94 comment="admin iPhone" list=Authorized
add address=192.168.10.2 comment="remote admin iphone" list=Authorized
add address=192.168.10.4 comment="remote admin laptop" list=Authorized
add address=192.168.10.5 comment="remote admin iPad" list=Authorized
"accept established, related, untracked" connection-state=\
established,related,untracked
add action=drop chain=input comment="Drop invalid" connection-state=invalid
add action=accept chain=input comment="accept ICMP" protocol=icmp
add action=accept chain=input comment="Accept LAN traffic" in-interface=\
"Local Bridge"
add action=accept chain=input comment="Allow Wireguard" dst-port=13231 \
protocol=udp
add action=accept chain=input comment="Allow Everything in Wireguard" \
in-interface=wireguard1
add action=accept chain=input comment="admin access" in-interface-list=\
TRUSTED src-address-list=Authorized
add action=accept chain=input comment="Allow DNS request for Container - UDP" \
dst-port=53 in-interface=dockers protocol=udp
add action=accept chain=input comment="Allow DNS request for Container - TCP" \
dst-port=53 in-interface=dockers protocol=tcp
add action=drop chain=input comment="block everything else"
add action=fasttrack-connection chain=forward comment=\
"Fasttrack, but not ipsec" connection-mark=!ipsec connection-state=\
established,related hw-offload=yes
"Forward established, related, untracked" connection-state=\
add action=drop chain=forward comment="Drop Invalid" connection-state=invalid \
log=yes log-prefix=invalid
add action=accept chain=forward comment="Forward all outbound traffic" \
in-interface="Local Bridge" out-interface="Port 8 - WAN" packet-mark=""
add action=accept chain=forward comment="Allow Wireguard to Subnets" \
dst-address=10.160.100.0/24 in-interface=wireguard1
add action=accept chain=forward comment="WG to internet" in-interface=\
wireguard1 out-interface="Port 8 - WAN"
add action=accept chain=forward comment="Accept dst-nat" \
connection-nat-state=dstnat
add action=accept chain=forward comment="Forward Docker Traffic to WAN" \
in-interface=dockers out-interface-list=WAN
add action=accept chain=forward comment="Docker forward rule" in-interface=\
"Local Bridge" out-interface=dockers
add action=drop chain=forward comment="Drop all Else"
add action=drop chain=forward out-interface-list=LAN src-address-list=\
back-to-home-lan-restricted-peers
/ip firewall mangle
add action=passthrough chain=prerouting comment=\
"special dummy rule to show fasttrack counters" disabled=yes
add action=mark-connection chain=prerouting comment="Newsgroup Traffic ipsec" \
connection-state=new dst-port=563 in-interface="Local Bridge" \
new-connection-mark=ipsec protocol=tcp
add action=mark-connection chain=prerouting comment="YouTube Traffic ipsec" \
connection-state=new disabled=yes dst-address-list=YouTube in-interface=\
"Local Bridge" new-connection-mark=ipsec protocol=tcp
"Local Bridge" new-connection-mark=ipsec protocol=udp
add action=mark-connection chain=prerouting comment="Mark Telegraph traffic" \
connection-state=new dst-address-list=VPN in-interface="Local Bridge" \
add action=mark-connection chain=prerouting comment=\
"Mark Telegraph ICMP traffic" connection-state=new dst-address-list=VPN \
in-interface="Local Bridge" new-connection-mark=ipsec protocol=icmp
"BitTorrent Ipsec (doesn't filter p2p traffic)" connection-state=new \
dst-port=16881 in-interface="Local Bridge" new-connection-mark=ipsec \
protocol=tcp
"BitTorrent DHT traffic UDP" connection-state=new dst-port=6881 \
in-interface="Local Bridge" new-connection-mark=ipsec protocol=udp
add action=change-mss chain=forward ipsec-policy=in,ipsec new-mss=1300 \
protocol=tcp tcp-flags=syn tcp-mss=1301-65535
add action=change-mss chain=postrouting ipsec-policy=out,ipsec new-mss=1300 \
add action=masquerade chain=srcnat ipsec-policy=out,none log=yes log-prefix=\
masq out-interface-list=WAN
add action=dst-nat chain=dstnat comment="Plex TCP" dst-port=32400 \
in-interface="Port 8 - WAN" log=yes log-prefix=PlexNAT protocol=tcp \
to-addresses=10.160.100.75 to-ports=32400
add action=dst-nat chain=dstnat comment=PiHole dst-address=10.160.100.1 \
dst-port=888 in-interface-list=LAN protocol=tcp to-addresses=172.17.0.2 \
to-ports=80
add action=dst-nat chain=dstnat comment=\
"Force any UDP DNS queries that aren't to pihole to go to pihole" \
dst-address=!172.17.0.2 dst-port=53 in-interface-list=LAN protocol=udp \
src-address=!172.17.0.2 to-addresses=172.17.0.2
"Force any TCP DNS queries that aren't to pihole to go to pihole" \
dst-address=!172.17.0.2 dst-port=53 in-interface-list=LAN protocol=tcp \
/ip ipsec identity
add auth-method=eap certificate="" eap-methods=eap-mschapv2 generate-policy=\
port-strict mode-config=NordVPN peer=NordVPN policy-template-group=\
NordVPN username=WNGqUUBXZkfY5c3q3SKMYDrY
/ip ipsec policy
add dst-address=0.0.0.0/0 group=NordVPN proposal=NordVPN src-address=\
0.0.0.0/0 template=yes
/ip service
set ftp disabled=yes
set telnet disabled=yes
set www disabled=yes
set www-ssl certificate=Webfig disabled=no
set ssh port=2200
set winbox address=10.160.100.0/24
set api disabled=yes
/ip smb shares
set [ find default=yes ] directory=/pub disabled=no
add directory=/usb1-part1 name=Container
/ip ssh
set strong-crypto=yes
/ipv6 address
add address=::4aa9:8aff:fe57:4601 from-pool=IPv6_Pool interface=\
"Local Bridge"
add comment="Docker container address range" from-pool=IPv6_dockers \
interface=dockers
/ipv6 dhcp-client
add add-default-route=yes interface="Port 8 - WAN" pool-name=IPv6_Pool \
prefix-hint=::/56 request=prefix
/ipv6 firewall address-list
add address=youtube.com disabled=yes list=VPN
add address=youtube.com list=YouTube
/ipv6 firewall filter
invalid
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" \
dst-port=33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
!listBridge
icmpv6
500,4500 protocol=udp
ipsec-ah
ipsec-esp
!listBridge
/ipv6 firewall nat
add action=masquerade chain=srcnat comment="Masquerade DNS traffic TCP" \
dst-address=fd6c:b6e2:f488::2/128 dst-port=53 protocol=tcp \
src-address-list=""
add action=masquerade chain=srcnat comment="Masquerade DNS traffic UDP" \
dst-address=fd6c:b6e2:f488::2/128 dst-port=53 protocol=udp
add action=dst-nat chain=dstnat comment="Force all UDP DNS queries to pihole" \
dst-address=!fd6c:b6e2:f488::2/128 dst-port=53 in-interface-list=LAN log=\
yes protocol=udp src-address=!fd6c:b6e2:f488::2/128 to-address=\
add action=dst-nat chain=dstnat comment="Force all TCP DNS queries to pihole" \
dst-address=!fd6c:b6e2:f488::2/128 dst-port=53 in-interface-list=LAN \
protocol=tcp src-address=!fd6c:b6e2:f488::2/128 to-address=\
add action=masquerade chain=srcnat comment="Masquerade for the Pihole" \
out-interface-list=WAN src-address=fd6c:b6e2:f488::/64
add action=dst-nat chain=dstnat comment=Pihole dst-address=\
fd94:4dc1:86fb::2/128 dst-port=888 in-interface="Local Bridge" \
in-interface-list=all protocol=tcp to-address=fd6c:b6e2:f488::2/128 \
to-ports=80
/ipv6 nd
add dns=fe80::4aa9:8aff:fe57:4601 interface="Local Bridge" \
managed-address-configuration=yes
/system clock
set time-zone-name=Europe/London
/system identity
set name=Gateway
/system logging
add action=disk topics=interface
/system ntp client
set enabled=yes
/system ntp server
set enabled=yes manycast=yes multicast=yes use-local-clock=yes
/system ntp client servers
add address=time.cloudflare.com
/tool bandwidth-server
set enabled=no
/tool graphing interface
/tool mac-server
/tool mac-server mac-winbox
set allowed-interface-list=TRUSTED
/tool romon
set enabled=yes
/tool traffic-monitor
add disabled=yes interface="Port 8 - WAN" name=tmon1
