Hi
I have setup AirPrint via CUPS in Ubuntu 12.04.03. This works through my main router, when my iPad and iPod are on this wifi router. That router is the main ADSL into the house. I then have another router, a MikroTik Routerboard, on an Ethernet cable attached to this. I use both of these networks for different iDevices, however the CUPS server is attached to the main router.
I think AirPrint only works on the local router, but I need to use it on both networks.
Is it possible to create some sort of tunnel to direct the AirPrint into the MikroTik router’s network?
Thank you.
