I just want to tell that Alcatel L850 4G modem is recognized as LTE interface in 6.27 ROS (the one I have tested). It works fine but it is needed to configure the modem via its web interface to connect automatically. On every reboot settings in the LTE interface are lost but this doesn’t mater as long as the modem has the right settings. Adding DHCP client on LTE interface is neccessary. Here are some specifications of it:
I don’t know about L800. I have tested L850 and L100. I can tell You that L850 is ok while L100 gets recognized in the latest ROS but it doesn’t work… It won’t initiate the connection.
Sorry , at the end I’m not sure whether Alcatel L850 LTE does have issues which spaxton mentioned or not ?
I will be using it on the remote location and it will be very important that after reboot , it connect automatically …
or my interpretation could be wrong and it works correct ?
You have to configure auto connect via the web interface of the modem using Your PC. It will auto connect in mikrotik. There were no issues actually, You can read my first post. I have mentioned only that LTE interface settings may be lost but it doesnt matter.
Can you help me about settings. I have MT RB951Ui-2HnD latest ROS ver.
I plug USM modem and have LTE1 interface show and below that ppp-out1.
I did masqurade on Lle1 but I can’t hava internet
What setings you did, to have internet ?
Plese help
You have to add DHCP client on LTE interface at first. There You can also choose to add the default route. The modem should be configured to connect automatically (this is done via web interface settings or the modem. Modem IP is 192.168.1.1)
Yes THANK YOU, I forget to settings DHCP Client ON LTE1… By default it is setup on LAN1 port.
Now, work like charm. ~ 45Mbs dowload, and ~20Mbs upload. For my needs more then great.
anyone solved DMZ issue with this modem? problem is that public IP is on the USB device, and on the web interface I could not find dmz or portforward settings, to be able to push the data to the mikrotik router
the device has no any kind of traffic filtration but it is NAT-ed. As far as I know, there is no way to change anything except the things You see in the web interface.
I have onetouch L850v and RB2011UiAS-2HnD and it is not recognised as lte interface and also i cannot see it on port list …Is there any specific configuration that i have to do to see it…???
I have try to reset usb and i saw it as lte interface.
If i want to use it as usb port how i can do it …???
I mean that i want to create a PPP Client interface and add it to usb port.
Now it is not appeared as usb available port.
If modems ins’t detected under system resources, or it doesn’t do mode switch then Please remove modem, power down board, then attach modem to board and power it up again.
Alcatel L850 & L800 have identical ID and firmware VID:1bbb; DID:f000 also should work in latest RouterOS
Under System Recources I can see the device ,
but when i try to setup a PPP Client interface and set the interface to usb there is no other choice exept serial0
in the drop down list .
I expected to see usb1 or usbX but nothing …
Also under sysmtem—> Ports usb not appeared …
For some new usb modems there is no serial port
Modems have only CDC_ECM driver and lte1 interface should appear.
Then you need to add dhcp-client to lte1 interface.
Hello kristaps,
It’s nice to see You here writting in my post… after we talked much via email about LTE interface in RB912. However, I have tested L850V with many routers and it works fine. Only with RB951 can’t achieve it’s maximum and I guess it’s because of USB interference. Also, this modem is certainly one of those without a serial port but it is easy to reach it’s configuration page just by typing 192.168.1.1 .
Best Regards!
How. Ive set up this modem for an RB951 i can see the lte interface but when i try to add a ppp interface no usb port is shown. So i add a dhcp client and i am getting an ip of 192.168.1.x, i create a nat rule for lte interface but i am not getting internet, however i can ping any public address like Google. Any ideas please ?
Στάλθηκε από το Redmi Note 3 μου χρησιμοποιώντας Tapatalk
First of all is that You can use this modem only as LTE interface as it is Hi-Link by default. There are maybe some firmwares which can convert it to non Hi-Link device but You don’t need that.
About the internet… Try to set DHCP client to use peer DNS and in DNS settings set allow remote requests in case You DHCP server is giving the gateway address as a DNS server.
