I upgraded my router to version 3.9 from 3.7, and it crashed after 2 days, now it constantly reboots every few minutes, does someone experiencing the same problem? I wish I keept the 3.7 files to downgrade.![]()
Starting to hear reports of this…
You can still get 3.7 here in gerald’s arcive of ROS…
http://www.shelbywireless.com/files/mikrotik/
Good day -Jordan
Hi thank you for the info but v 3.5 is the last one on the site. I manage to get 3.7 downgrade in netinstal and loose my license..what can I say beginner bad luck or bad licensing system from mikrotik, a bit of both actually.
I send support files to mikrotik support, if they are able to find the problem. Also v 3.7 was not behaving 100% ok, the terminal window chrashed 1 out of 5 times I open it. Also connectivity with winbox is often disconnected (i’m using IP to connect).
When I tested the “DEMO” version I didn’t have these problems, but I had different CF card 64Mb Sandisk, but I installed the purchased version on brand new 2Gb sandisk extremeIII card. Is it possible that CF card is somehow bad? and this is causing the problems?
