I’m tring to install Routeros 3.23 in the Alix 2D3, trought a 2GB CF card.
I downloaded
- netinstall-3.23
- all_packages-x86-3.23.zip
Well, in Windows XP I plugged the CF card and CF reader.. so I selected all of the packages, selected the correct label drive, setted the boudrate to 9600 and pressed Install.
The process well done.
But.. when I switch-on the Alix …
this is what I see on the TeraTerm Serial Terminal (COM1, 9600) freeze here, and no more.
01F0 Master 848A LEXAR ATA FLASH CARD
Phys C/H/S 3977/16/63 Log C/H/S 994/64/63
PC Engines ALIX.2 v0.99h
640 KB Base Memory
261120 KB Extended Memory01F0 Master 848A LEXAR ATA FLASH CARD
Phys C/H/S 3977/16/63 Log C/H/S 994/64/63SYSLINUX 2.08 2003-12-12 Copyright (C) 1994-2003 H. Peter Anvin
May you help me?
thanks
