all 3 -ports ethernet RB433H disabled
I mistakely disabled all the 3 ethernet ports of my RB433H and l have been trying to connect to the board through Winbox, but all the effort was zero. pls kindly assist in order to reset the board to default settings.
Ok, what you need is a hammer…
Connect via a serial cable, telnet into the router and enable them again
try ingress via mac-address.
regards
Am very grateful for your kind assistance. l have done that and is now working fine
Hi!
Where I can find a serial cable for mikrotik? Is it the same used by cisco routers? In this case, may I use the same parameters to login?
Tnx!
:slight_smile:
http://wiki.mikrotik.com/wiki/First_time_startup
Did the Hammer work ?
