All GRE tunnels went down on CCR
Hello, I have had a problem on our CCR1009-8G-1S where all the GRE tunnels went down. When I watched the tunnels, I could see that nothing was being sent over it. I had Keepalive turned on but I never saw any outgoing packets.
To try and fix it I tried turning keep alive off and back on, but didn’t help.
I didn’t think of disabling and re-enabling the GRE tunnels until later.
I ended up rebooting the router and that fixed things.
Is this a known problem or is there something I should know about GRE tunnels over IPsec that I am missing?
I am fairly new to Mikrotiks and to OSPF over GRE over IPsec too. But when it works, it rocks!
the same problem
Will try to turn off IPSec on one tunnel and switch to IPIP mode on another.
And it failed again over the holiday weekend. I wish I could switch to IPIP but I need multicast for OSPF. While I was diagnosing the problem, I tried to disable one of the GRE tunnels and it’s associated IPSec peer/policy then re-enable it but that did not bring up the tunnel.
So I ended up rebooting the router and then all GRE tunnels came back up.
This is really annoying as this is one of our core routers. And GRE is such a simple protocol – what in the world is going on here?!
