All LEDs always on RB OmniTIK U-5HnD
Hi there,
I’ve just unboxed a brand new RB OmniTIK U-5HnD. I updated both RouterOS and RouterBoard to the latest versions. The device has no configurations and I’ve reset it 10 times.
Now as I plug the PoE Ethernet plug into any switch, all RB OmniTIK U-5HnD’s LEDs turn on.
I changed power supply, POE, Ethernet cable and switch. RB OmniTIK U-5HnD seems to work fine but I don’t want to put it on a production site.
What can I do?
Try to remove the configuration and set the leds on your own.
I’ve reset it 10 times. What you mean about set led?
Try with Original power supply and connect omnitik to pc or laptop.
Is that still the same?
The switch that you connect with omnitik is that i switch with POE?
I’ve used original power supply, original Gigabit POE on 3 OmniTik with no configuration (system reset no default=yes) with the latest RouterOS and firmware.
The problem is this: as I connect the POE to any Ethernet port all 6 leds turn on
Look at theese three pictures
What could be the cause? I changed POE, power supply and switch
It’s the same by my omnitiks but she working fine
What RouterOS version are you using?
RouterOs 6.12 have tryed wit 6.14rc1 but still the same
I’ve got this problem also with RouterOS 6.11. Do you have your Omnitik in a production environment?
Yes, but everything is fine
Thank you.
I hope Mikrotik will check this issue. Do I have to open a ticket?
You re welcome thanks for add karma
Now’ i open a ticket for that.
