all ports to bridge
  1. I have a 48 port switch, how do I get all ports in one bridge with a script?
  2. We have VLANS on the bridge, can you use all or dynamic?
To slap all ports into the same bridge
foreach i in=[interface find] do={interface bridge port add interface=$i bridge=(YOUR BRIDGE INTERFACE)}
this was another script from the other day, someone wanted x vlans in the bridge>vlans config that were concurrent, idk if you can make some use out of it as well, count will be the start, will go up 1 vlan per run, either add the other ports in the tagged= or alternatively have some fun and see if you can incorporate some of the code into that so you dont have to :slight_smile:
local count (number here at the vlan you want to start at)
foreach i in=[interface bridge vlan find] do={ local vn [interface bridge vlan find vlan-ids=$count] ; interface bridge vlan set numbers=$vn tagged=ether1,ether2,ether3,ether4,ether5; if ($count<=10) do=[set count ($count + 1)] }
