All traffic over VPN
I bought this device to achieve a simple goal but as it’s so complex, it’s not as straightforward as I’d hoped.
The idea is that the Mikrotik router simply acts as a VPN client, and any devices connected to it, are served data from the VPN.
Basically I have managed to set up a PPTP connection on the Mikrotik router, this connects absolutely fine.
However I want ALL internet traffic to travel over this connection and at the moment, it doesn’t seem that any does.
I’ve scoured the web and these forums and not turned up anyone doing something seemingly so simple. Any pointers are appreciated!
What you need is to set the VPN connection as the default route.
You can set this by ticking the Add Default Route parameter on the PPTP-Client Interface Dial Out tab settings to achieve that automatically.
You’ll also need to add a IP > Firewall > Nat masquerade or srcnat rule for traffic exiting via the PPTP-Client interface.
Thanks for the reply.
I already had that “add default route” box ticked, which is why I was surprised it didn’t work as expected.
I’ll take a look at the NAT setting you mention, and report back. Thanks!
please check your nat. should be like that;
add action=masquerade chain=srcnat out-interface=PPTP-Client
What kind of VPN are you using?
PPTP needs some firewall rules.
IP → Firewall
ADD NEW
Chain → input
Protocol → GRE (Protocol 47)
APPLY and OK (no port or anything else needed)
Same rule with Chain → output with GRE
APPLY and OK
And now add the last rule
CHAIN → input
Protocol → TCP
Destination Port (Dst. Port) → 1723
For all needs I would add following ports to your firewall too.
Input - UDP - Dst. Port 500
Input - IPSEC-ESP - (no port)
Input - TCP - Dst. Port 80 and 8291
the first 2 are for ipsec and the last tcp ports are for webinterface and winbox via WAN.
There are of course some more rules if you want to use another vpn like IPIP or whatever.
For your needs it should work like this.
Try this. I hope your default route (IP → Routes) is set right, too.
What kind is your uplink? PPoE, Static LAN IP? Static Public IP?
If you are behind another router and dont have a public IP (or PPoE Uplink) the main router will need some ports and protocoll forwardings, too. (like GRE and TCP)
Maybe in routes (IP → Routes) you will need one manual entry, too.
P.S.: ALMOST FORGOT IT!
You have to move the firewall rules to the TOP over the DROP.
CLICK and HOLD the rule in the overview and move it up over the last DROP action.
Well there are ways how you should sort it, that a packet dont have to run again and again rules which are not needed often. In your case start like this first.
Sorting your firewall rules will be a part later if you have more, and more … and too much rules :wink:
Would I need to modify firewall rules, for outgoing VPN? Again to clarify, I’m not connecting to a Mikrotik router. I’m setting one up as a VPN client. The VPN server is already set up and tested, working fine.
I will try the NAT thing.
No firewall rules needed for outgoing VPN, DaKater rules are targeted for providing VPN service. Just the NAT rule.
It sounds like you need to srcnat allow your local lan subnet to the remote lan subnet.
You would add this in /ip > firewall > NAT:
src local lan subnet
dst remote lan subnet
action: allow
And you should masq internal subnet out to your ppp or vpn interface.
The last line is what I was missing. I added this and all works perfectly. Thank you!
Hi everyone…bump!
can anyone help me add specific traffic to VPN?
(port 2 on the router).
