Can anyone help with routing all traffic via IPSEC tunnel?
src-address=10.170.1.0/24 src-port=any dst-address=10.161.1.0/24
dst-port=any protocol=all action=encrypt level=require ipsec-protocols=esp
tunnel=yes sa-src-address=SA.SA.SA.SA sa-dst-address=DA.DA.DA.DA
proposal=default priority=0
10.170.1.0/24 is remote office network
10.161.1.0/24 is data center network
Traffic from 10.170.1.0/24 to 10.161.1.0/24 is working fine adn reaching 10.161.1.0/24 network.
Now what I need is traffic from 10.170.1.0/24 to 0.0.0.0/0 also to go through ipsec tunnel to 10.161.1.1 destination.
The idea is that remote office must browse internet via data center.
Hi, Remote Network can’t get Internet via IPsec because parameters “Policies” or “Cryptomap” called don’t match to destination address 0.0.0.0/0.
So i see two solutions for you:
On Data Center Router side use NAT masquarade for source address 10.170.1.0/24 and destination interface WAN.
Use GRE tunnel on edges of IPsec tunnels ( typically it’s called GRE over IPsec) then address both of GRE tunnel ends
for example:
192.168.0.1/30 for remote office
192.128.0.2/30 for data center
What I do is create a L2TP or GRE tunnel then encrypt the tunnel with IPSec. Once I have that I create a /30 network on the tunnel and create a default route with a routing mark to the “data center”. Then create a mangle rule to send desired traffic to the new routing table. Instead of using /ip mangle you could also use /ip route rule.
I know this is vague but it should give you the general idea.
