All version packages
Is there somewhere we can download all the package versions of RouterOS?
Best Regards,
Pedro
why do you need versions other than what is here? http://www.mikrotik.com/download.html
Hi normis,
It has happened in cases where time to establish a backup of different versions, we got an error when pasting file. RSC.
We find it best to downgrade and then proceed with the restore procedure.
You know where I can find these earlier versions?
Best regards,
Pedro
They have several version available, just edit the link manually, you can usually grab 3 or 4 versions back that way.
As far as I know they do not maintain a publicly accessible repository of older versions. You can contact support and ask them for it, or someone on the forum might be nice enough to give you temporary access to their files, but don’t count on it.
Sometimes syntax changes in a version, look where the errors are and correct them, they are highlighted by a red mark in the terminal as you past it to the RB.
Great! Thanks for listening!
For me it worked very well in the url by changing the name of the desired version.
Thank you!
http://mikrotik.online.ir availble on both ipv4 and ipv6.
Regards,
Arash Naderpour
