We have HAP AX3 that has had wifi issues since being installed.
All things on the wifi drop off and if any user tries to reconnect they get told the password is wrong, the only solution is to reboot the router. Even if you disable and re-enable the wifi interfaces, this won’t kick the connection back in.
The router has been firmware 7.10 which I understand should sort this issue for a lot of people, but it’s made no difference at all
The only thing showing in the logs when I looked was key handshake timeout on loads of devices . I have added to the interface security for both connections group key update to 1 hour as reading through the forums I see this had helped a lot of people but this has made no difference at all.
The customer is getting quite annoyed and I don’t blame him to be fair but anyone else got any clues? I also include an export of the config excluding personal stuff
# model = C53UiG+5HPaxD2HPaxD
add admin-mac= auto-mac=no comment=defconf name=bridge
set [ find default-name=ether1 ] name=ether1-WAN1
/interface wifiwave2
set [ find default-name=wifi1 ] channel.band=5ghz-ax .skip-dfs-channels=\
10min-cac .width=20/40/80mhz configuration.country="United Kingdom" .mode=\
ap .ssid=MikroTik-972832 disabled=no security.authentication-types=\
wpa2-psk,wpa3-psk .group-key-update=1h
set [ find default-name=wifi2 ] channel.band=2ghz-ax .skip-dfs-channels=\
10min-cac .width=20/40mhz configuration.country="United Kingdom" .mode=ap \
.ssid=MikroTik-972833 disabled=no security.authentication-types=\
wpa-psk,wpa2-psk .group-key-update=1h
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether1-WAN1 name=pppoe-out1 \
use-peer-dns=yes user=
add comment=defconf name=WAN
add comment=defconf name=LAN
/ip ipsec proposal
set [ find default=yes ] auth-algorithms=sha1,md5 enc-algorithms=\
aes-256-cbc,aes-128-cbc,3des lifetime=1h pfs-group=none
add name=default-dhcp ranges=192.168.1.100-192.168.1.199
add address-pool=default-dhcp interface=bridge lease-time=3d name=defconf
/port
set 0 name=serial0
/system logging action
set 1 disk-file-count=9
add bridge=bridge comment=defconf interface=wifi1
add bridge=bridge comment=defconf interface=wifi2
/ip settings
set tcp-syncookies=yes
/ipv6 settings
set max-neighbor-entries=15360
add comment=defconf interface=ether1-WAN1 list=WAN
add address=192.168.1.254/24 comment=defconf interface=bridge network=\
192.168.1.0
/ip cloud
set update-time=no
/ip dhcp-client
add address=192.168.1.0/24 comment=defconf dns-server=192.168.1.254 gateway=\
192.168.1.254
set allow-remote-requests=yes
/ip dns static
add action=jump chain=input comment="Jump to ICMP Chain" jump-target=ICMP \
protocol=icmp
add action=accept chain=input comment="Accept established, related connections" \
add action=accept chain=input comment="Access from bridge" in-interface=bridge
add action=accept chain=input comment="remote access to MT" dst-port=\
22,80,6009,8291 in-interface=all-ppp protocol=tcp src-address-list=\
remote_access
add action=accept chain=input comment="VPN - IPSEC ESP" disabled=yes \
in-interface=all-ppp protocol=ipsec-esp
add action=accept chain=input comment="VPN - L2TP over IPSEC" disabled=yes \
dst-port=500,1701,4500 in-interface=all-ppp protocol=udp
add action=drop chain=input comment="Drop invalid connections" \
connection-state=invalid
add action=drop chain=input comment="Drop everything else"
"Accept established, related connections" connection-state=\
established,related
add action=accept chain=forward comment="Forward bridge" in-interface=bridge \
out-interface=all-ppp
add action=drop chain=forward comment="Drop invalid connections" \
add action=drop chain=forward comment="Drop everything else except dst-nat" \
connection-nat-state=!dstnat connection-state=new
add action=accept chain=ICMP comment="Allow Echo Reply" icmp-options=0:0 limit=\
50,5:packet protocol=icmp
add action=accept chain=ICMP comment="Allow Echo Request" icmp-options=8:0 \
limit=50,5:packet protocol=icmp
add action=accept chain=ICMP comment="Allow Traceroute TTL Exceeded" \
icmp-options=11:0 limit=50,5:packet protocol=icmp
add action=accept chain=ICMP comment="Allow Traceroute Port Unreachable" \
icmp-options=3:3 limit=50,5:packet protocol=icmp
add action=accept chain=ICMP comment=\
"Allow Traceroute PMTUD (Fragmentation Required)" icmp-options=3:4 limit=\
add action=drop chain=ICMP comment="Drop all other types of ICMP"
add action=masquerade chain=srcnat comment="Default out" out-interface=\
pppoe-out1
/ip firewall service-port
set sip disabled=yes
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set www-ssl certificate=SSL disabled=no port=6009
set api disabled=yes
set api-ssl disabled=yes
/ip ssh
set forwarding-enabled=both strong-crypto=yes
/ipv6 firewall address-list
/ipv6 firewall filter
established,related,untracked
invalid
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
"defconf: drop everything else not coming from LAN" in-interface-list=!LAN
add action=drop chain=forward comment="defconf: drop invalid" connection-state=\
invalid
add action=drop chain=forward comment="defconf: drop packets with bad src ipv6" \
src-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: drop packets with bad dst ipv6" \
dst-address-list=bad_ipv6
icmpv6
add action=accept chain=forward comment="defconf: accept IKE" dst-port=500,4500 \
protocol=udp
ipsec-ah
ipsec-esp
/system clock
set time-zone-autodetect=no time-zone-name=Europe/London
/system identity
set name=Mac-Gateway
/system logging
set 0 action=disk
set 1 action=disk
set 2 action=disk
set 3 action=disk
/system note
set show-at-login=no
/system ntp client
set enabled=yes
/system ntp client servers
add address=0.uk.pool.ntp.org
add address=1.uk.pool.ntp.org
/tool bandwidth-server
set enabled=no
/tool mac-server
/tool mac-server mac-winbox
