Allocate /29 to PPPOE Customer
Hi Guys,
I have a customer who has requested a /29 subnet allocated to their connection.
Usually all our customers get a single IP from an IP pool on the Lac.
We use Dalo radius and any customer who wants a public IP we usually allocate it there.
Although if i try and allocate an IP with a /29 etc the user is unable to authenticate,
Anyknow know the best way around this?
if the /29 is, for example 13.14.15.16/29 (13.14.15.16 - 13.14.15.23)
assign one private ip to radius profile, like 10.0.0.2
and
add to route list
dst 13.14.15.16/29 → gat 10.0.0.2
and assign 13.14.15.17/29 to ether1 on the cpe
add 13.14.15.18-13.14.15.22 on the dhcp server pool list inside the cpe
So you are currently just giving them a Framed-IP-Address response, this contains a single IP address.
You just need to use the Framed-Route attribute and define a subnet, gateway and distance e.g.
Framed-Route := 203.96.1.0/29 0.0.0.0 100
This would route 203.96.1.0/29 at the IP dynamically given to the client as a Framed-IP-Address with distance of 100. This will be added to the Mikrotik as a “Dynamic Static” route.
This should be working at this point.
If you are doing this with DHCP/IPoE you need to also
/ip dhcp-server set 0 use-framed-as-classless=no
as somewhere in the RouterOS 6 chain of releases Mikrotik broke the use of the Framed-Route attribute, instead of adding the framed-route it started assigning it to the client as a classless-route, making RouterOS 6 noncompliant with the RFC.
