i my network i am having problem of same mac address. 2 users on same point have same mac address so now its connecting and disconnecting again and again i am using Mikritik 850gx.
and in log it is showing - pppoe connection from (mac address) was already active- closing previous one.
then it disconnect one and connect other after 30-40 sec again disconnect and connect…repeat
pleases help me out.
Duplicate mac addresses are not allowed on the same Layer2 network. One of them will need to change their mac address. If you backup 1 Mikrotik, the mac addresses of the interfaces are backed up too. If you restore that config to a different Mikrotik, the mac addresses are applied to the new device. So if you backup a config and apply it to many Mikrotiks, you have to reset the mac to default on the cloned Mikrotiks.
