Allow access to lan NAS withing wireless networks
Hello.
Recently I’ve upgraded our home network with a lovely NAS. It is sitting on one of the lan ports and I have no problem at all using it from my PC on the same network. However, if I try to access it via //MYCLOUDULTRA folder from my laptop connected to wifi a connection error displays instead. Both my PC and laptop are using Windows 11 and have the network set to private with network discovery enabled. Is there some way how to allow connections from wifi networks to the NAS on lan?
Thanks!
And how is that ax3 configured ?
Without that info, lots of guessing…
Sorry. Here is the configuration:
VLAN: Name: vlan848, Interface: ether1
PPPoE Client: Name: pppoe-out1, Interface: vlan848, Max MTU/MRU: 1492
DNS: 8.8.8.8
NAT: Chain: scrnat, Out interface: pppoe-out1, Action: masquerade
IPv6: Interface: pppoe-out1, Request: Prefix, Pool Prefix Length: 56, Address: ::/64, Interface: bridge, Destination Address: ::/0, Gateway: pppoe-out1, ND MTU: 1492
Wifi 5Ghz: Interface: wlan1, Settings: default, changed - region to Czech Rep., SSID name, and password
Wifi 2,4Ghz: Interface: wlan2, Settings: default, changed - region to Czech Rep., SSID name, and password
I’m new with mikrotik so if there is more simple way how to forward configuration. Please let me know :slight_smile:
/export file=anynameyoulike
Remove serial and any other private info, post between code tags by using the </> button.
The default configuration of an Ax3 (and most other Mikrotik Soho devices) has 1st port (ether1) as WAN and all other ethernet and wanports in a bridge as LAN
So a wlan interface (either wlan1 or wlan2) should have exactly the same behaviour of ether 2-5.
Can you describe exactly the connection error you are having and “when/where”[1] it happens?
Also when connected to the wi-fi can you access other devices connected to the LAN (the PC, the cap Ax)?
[1] meaning is it a Windows OS error, is it in the browser, is it in a file manager, etc. ?
Sorry for late reply. Finally I have some time off work. Here is dump of my settings:
add admin-mac=xxx auto-mac=no comment=defconf name=bridge
/interface wifi
set [ find default-name=wifi1 ] channel.band=5ghz-ax .skip-dfs-channels=\
    10min-cac .width=20/40/80mhz configuration.country=Czech .mode=ap .ssid=\
    Gateway-Wireless-5GHz disabled=no security.authentication-types=\
    wpa2-psk,wpa3-psk .ft=yes .ft-over-ds=yes
set [ find default-name=wifi2 ] channel.band=2ghz-ax .skip-dfs-channels=\
    10min-cac .width=20/40mhz configuration.country=Czech .mode=ap .ssid=\
    Gateway-Wireless disabled=no security.authentication-types=\
/interface vlan
add interface=ether1 name=vlan-848 vlan-id=848
/interface pppoe-client
add add-default-route=yes disabled=no interface=vlan-848 max-mru=1492 \
    max-mtu=1492 name=pppoe-client1 user=cetin
add comment=defconf name=WAN
add comment=defconf name=LAN
add address-pool=default-dhcp interface=bridge name=defconf
/disk settings
set auto-media-interface=bridge auto-media-sharing=yes auto-smb-sharing=yes
add bridge=bridge comment=defconf interface=wifi1
add bridge=bridge comment=defconf interface=wifi2
/interface ovpn-server server
add mac-address=xx name=ovpn-server1
    192.168.88.0
/ip dhcp-client
    192.168.88.1
set allow-remote-requests=yes servers=1.1.1.1,1.0.0.1
/ip dns static
add address=192.168.88.1 comment=defconf name=router.lan type=A
    established,related,untracked
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
add action=masquerade chain=srcnat comment="defconf: masquerade" disabled=yes \
add action=masquerade chain=srcnat out-interface=pppoe-client1
add action=redirect chain=dstnat dst-port=53 protocol=udp to-ports=53
/ip ipsec profile
/ipv6 address
add address=::xxx from-pool=O2 interface=bridge
/ipv6 dhcp-client
add interface=pppoe-client1 pool-name=O2 pool-prefix-length=56 request=prefix
/ipv6 firewall address-list
/ipv6 firewall filter
    invalid
    icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" \
    dst-port=33434-33534 protocol=udp
    udp src-address=fe80::/10
    protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
    icmpv6
    500,4500 protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
/ipv6 nd
set [ find default=yes ] hop-limit=64 mtu=1492
/system clock
set time-zone-name=Europe/Prague
/system note
set show-at-login=no
/system routerboard wps-button
set enabled=yes on-event=wps-accept
/system script
add comment=defconf dont-require-permissions=no name=wps-accept owner=*sys \
    policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon \
    source="\r\
    \n   :foreach iface in=[/interface/wifi find where (configuration.mode=\"a\
    p\" && disabled=no)] do={\r\
    \n     /interface/wifi wps-push-button \$iface;}\r\
    \n "
/tool mac-server
/tool mac-server mac-winbox
Currently, the NAS has IP 192.168.88.246. I can ping it from my laptop on wifi. However, when I try to open it in explorer, it fails. In network tab in the explorer I can see the NAS listed by its full name. But once I try to open it, the same error emerges.
Please note that I changed the lan port of NAS to verify it’s not port issue and completely removed Cap ax from the equation - to verify I’m connected to hAP ax3 wireless network.
Very likely it is one of the cases listed here:
https://learn.microsoft.com/en-us/troubleshoot/windows-client/networking/cannot-access-shared-folder-file-explorer
https://www.qnap.com/en/how-to/faq/article/what-cant-i-access-nas-shared-folders-with-windows-file-explorer-smb
These kind of issues are usually a big PITA to troubleshoot, as there can be several different settings that affect the behaviour.
What happens if trying to map a drive with net use on command line?
https://ss64.com/nt/net-use.html
Locally saved credentials could not match current NAS settings (even the name is still the same) and Windows deny to access resource.
It says the path does not exist
So problem is on my laptop? Because previously I connected via ethernet and now I want to use wifi and Windows keeps credentials for ethernet? The root folder of NAS is accessible for anyone on network only user folders need credentials
