I want my hotspot users to be able to view their usage statistics via the vpn IP of my radius server (which in this case is a mikrotik CHR). But this means they can also access the router login page on port 80 using the same IP address?
How do I allow users to access http://192.168.88.1/user and block them from accessing the router webfig homepage on http://192.168.88.1 ?
…If you completely want to disable that page, email support about a branding package, that lets you customize the HTML
At least I now know it it possible to have a customized version of webfig on you routerOS. I will email support and see how I can completely remove the login option on my routerOS webfig page. That way even if you visit the page, you won’t see any option to login from there.
