Allow internet acces on one port for private lan range
I have pppoe internet access, one bridge, all works fine
one rule in nat
add action=masquerade chain=srcnat out-interface=pppoe-out1
now i want to take one port from that bridge, for example ethernet3 to NOT be in bridge and not have any address assigned.
I would like to make such thing that any statically assigned addres in pc network card, connected to port ethernet3 (which is not in bridge),
also have access to internet.
So for example user connects pc to this separate port etherent3, goes into control panel, assigns any ip address from private range, and has internet access.
Is that possible?
I dont want him to have access to local lan, only internet with any private address he wants.
what rules should i add in nat?
If ethernet3 port has assigned some static address, than no problem, I know how to do it.
But without address i dont know
Quite easy.
If you are aware of configuration for the bridge you already have, then create the second bridge with the only eth3 port assigned,
clone configuration from current bridge but use IPs from the “other” pool.
