i am an IT Operator in a University, i have a list of mac’s that are allowed to access the internet from a Mikrotik Device, so i want to allow this list to access internet and reject or prevent all others.
there are no address-list for mac-addresses in ROS[/quote]
Does this mean that I cannot do MAC address filtering?
I need to limit access to and via a 711 to just one piece of equipment with one MAC address.
I have two 711’s configured as a point to point link with a bridge from wlan to ether set up on them both.
One end (office) has a switch and 4 PC’s connected.
The other end has a video recorder connected that is viewed from one of the PC’s in the office.
The recorder has a static IP address.
The problem I have is that a “nice” person unplugs the DVR and connects a PC in it’s place. The person can now access anything on the other end of the radio link.
I think (occasionally, but today is not one of those times) that if I could use mac address filtering I could stop this happening by allowing traffic to and from one mac address only.
I have tried using a firewall in the bridge from wlan to ether but can’t get it to work ( I can get it to work using IP address filtering, but the person is clever enough to set his PC to the same IP address as the recorder)!
If the remote device has a fixed IP and you are worried that some bad guy unplugs this good device, then changes his laptop to the same IP as the good device, it is very easy to block him from getting internet.
Look in ARP table (IP/ARP) change the dynamic ARP entry for the ‘good device’ to a static one so it never dissapears. Then on the interface facing the connection that can be used by this bad guy, change the ARP setting to reply-only.
Now, only if the laptop has the same MAC address as the good device can they get onto network.
Make sure you add all the other devices that share this same physical interface to the static ARP table list of MAC addresses, otherwise all those devices will not connect either.
