I can ssh from the client on 10.1.1.200 to the server at 10.1.1.10.
I can ping from the mikrotik server on 10.1.1.1 to the VPN client at 10.1.1.200.
I can NOT ping from the home server on 10.1.1.10 to my VPN client at 10.1.1.200.
I'm trying to troubleshoot where things are failing. I'm currently unclear if this is a firewall configuration issue, or a routing issue, or something else. And more importantly, I'm curious how I'd debug this. I use the Web UI and ssh interface to manage the Mikrotik. What tools are recommended to determine where things are getting confused?
Thank you for the quick reply. I’m reviewing the routing configuration now, there is an automatically added routing but perhaps that’s not sufficient? (In this table, its called .)
[MikroTik] /routing/route> print
Flags: U, A - ACTIVE; c, s, d, y - COPY; H - HW-OFFLOADED
Columns: DST-ADDRESS, GATEWAY, AFI, DISTANCE, SCOPE, TARGET-SCOPE, IMMEDIATE->
DST-ADDRESS GATEWAY AFI D SC TA IMMEDIATE-GW
Ad 0.0.0.0/0 192.168.8.1 ip4 1 30 10 192.168.8.1%isp1
d 0.0.0.0/0 192.168.1.1 ip4 2 30 10 192.168.1.1%isp2
Ac 10.1.1.0/24 home ip4 0 10 home
Ac 10.1.1.200/32 <l2tp-jeremy> ip4 0 10 <l2tp-jeremy>
Ac 172.16.100.0/24 dmz ip4 0 10 dmz
Ac 192.168.1.0/24 isp2 ip4 0 10 isp2
Ac 192.168.8.0/24 isp1 ip4 0 10 isp1
A H ether1 link 0
A H <l2tp-jeremy> link 0
A H ether3 link 0
A H ether5 link 0
A H ether7 link 0
A H mylan link 0
A H isp1 link 0
A H dmz link 0
A H isp2 link 0
If the VPN client uses an address which overlaps with the local subnet you have to enable proxy-arp so the Mikrotik replies to ARP requests from local devices on behalf of the VPN client.
However, as you say you can SSH from the client on 10.1.1.200 (the VPN connection) to the server at 10.1.1.10 (on the local network) then proxy-arp must already be enabled, in which case it is likely firewall rules.
Is it a problem that I’ve placed my remote client w/in this subnet? (The L2TP client is being assigned an IP address of 10.1.1.200.) This has worked fine until I needed to connect from my home network to the report client, at which time I realized I’m unable to initiate connections in that direction.
I’m both hoping to resolve this, as well as to understand the proper steps to debug where requests are being dropped. The firewall (10.1.1.1) can ping the remote VPN client (10.1.1.200) so it knows how to get there. But a server on my local network (10.1.1.10) can not ping the remote VPN client through the firewall – it’s unclear to me if this is a routing issue, or a packet filter issue: and I’m struggling to debug.
And … sorry, it was indeed as simple as enabling proxy-arp on my local network. I’m now able to both ping the server from the client, and the client from the server. Thanks!
