Allow RDP only for selected IP's
Hi all.
I have a few port-forward rules, to 2 of them everyone can connect.
add action=dst-nat chain=dstnat comment="Port Forward" disabled=no dst-port=9999 protocol=tcp to-addresses=192.168.0.3 to-ports=3389
add action=dst-nat chain=dstnat comment="Port Forward" disabled=no dst-port=2010 protocol=tcp to-addresses=192.168.0.4 to-ports=3389
But to one computer just specific/selected IP should have the right to connect, I made the list and the rule but it doesn’t work, what is the correct rule to deny everyone except selected IP’s ?
This one doesn’t work, I still can connect from any IP:
add action=dst-nat chain=dstnat comment="Port Forward" disabled=no dst-address-list=ALLOW dst-port=1111 protocol=tcp to-addresses=192.168.0.2 to-ports=3389
Thank you in advance.
If you want to allow only specific addresses that are able to connect to RDP then it should be src-address-list=ALLOW
ty, my fault :slight_smile:
