Allow SMB via two pptp connected Routerboards (RB751Uh-2HnD)
Good Day,
I am trying to enable SMB support for hosts between two Routerboards which are connected via pptp vpn.
I can access the server from 192.168.2.0/24 to 192.168.1.5 but not to any of the other hosts in 192.168.1.0/24 segment. The same is for opposite. Should I add some additional routes in both endpoints and open 137 and 139 port ?
Thank you.
192.168.1.1
[user@192.168.1.1] > /ip address print
 #   ADDRESS            NETWORK         INTERFACE
 0   ;;; default configuration
     192.168.1.1/24     192.168.1.0     bridge-local
 1   11.22.33.44/24   11.22.33.0    ether1-gateway
 2 D 192.168.20.1/32    192.168.20.2    <pptp-serviss>
[user@192.168.1.1] > /ip route print
 0 A S  0.0.0.0/0                          84.237.234.1              1
 1 ADC  11.22.33.0/24    11.22.33.44   ether1-gateway            0
 2 ADC  192.168.1.0/24     192.168.1.1     bridge-local              0
 3   S  192.168.1.0/24                     192.168.20.2              1
 4 A S  192.168.2.0/24                     192.168.20.2              1
 5 ADC  192.168.20.2/32    192.168.20.1    <pptp-serviss>            0
192.168.2.1
[user@192.168.2.1] > /ip address print
     192.168.2.1/24     192.168.2.0     bridge-local
 1   55.66.77.88/24   55.66.77.0    ether1-gateway
 2 D 192.168.20.2/32    192.168.20.1    AverAutoBirojs
[user@192.168.2.1] > /ip route print
Flags: X - disabled, A - active, D - dynamic, C - connect, S - static, r - rip, b - bgp, o - ospf, m - mme, B - blackhole, U - unreachable, P - prohibit
 0 A S  0.0.0.0/0                          55.66.77.1              1
 1 ADC  55.66.77.0/24    55.66.77.18   ether1-gateway            0
 2 A S  192.168.1.0/24                     192.168.20.1              1
 3 ADC  192.168.2.0/24     192.168.2.1     bridge-local              0
 4   S  192.168.2.0/24                     192.168.20.1              1
 5 ADC  192.168.20.1/32    192.168.20.2    AverAutoBirojs            0
