Allowing 100 sip connection to pbx
Hello All. I hope you are doing fine
What I want is enable just 100 sip connection to the PBX through mikrotik router. So, I think that the code in the mikrotik firewall filter should be:
ip firewall filter add chain=forward dst-address=100.64.0.2 protocol=udp dst-port=5060 action=accept connection-limit=100,32
Thats correct?
Also, just to add more lines in the firewall filter I red that this lines should be at the list beginning.
ip firewall filter add connection-state=established action=accept chain=input
ip firewall filter add connection-state=related action=accept chain=input
ip firewall filter add connection-state=invalid action=drop  chain=input
But, What this lines do? because is not define an ip, port, or protocol.
Thanks in advance and best regards.
These rules apply filtering according to the state of the connection. The firewall has connection tracking so it “remembers” each connection
and you can e.g. pass all traffic related to established connections. When you put that rule at the start, the router does not have to evaluate
all your rules for each packet passing by, but it can pass packets related to established connections (which it has validated before) quicker.
What are you trying to achieve?
Limiting to 100 connections in this way makes you susceptible to a DoS attack. Any SIP device on the internet will get scanned multiple times a day by various bots, which could exhaust available connections and block genuine clients.
Thanks, both.
The doubt regarding why is that lines at the beginning is over!
Regarding the connection limit. What I want is just limit the maximum connection at one’s time (not the total )that the PBX can handle. Becuase it depends on the ISP bandwidth connection, upstream connection because that are for packages which are coming from the public network.
So what I want is limit the number of signaling (sip packages) which are forwarding the router.
It’s wrong the code for what I want to do?
Due to the connection-tracking required, I think connection-limit only applies to TCP traffic, not UDP.
I may be wrong on this one, but I’m fairly sure that’s what your problem is. You also want to be on the forward chain, not the input chain (your three connection-tracking rules).
And what about this next rule?
add action=drop chain=forward comment="Limit to 100 udp connections" connection-state=new disabled=no dst-port=5060,10000-65535 connection-limit=100,24 protocol=udp
