Allowing Facetime
I would like to allow facetime traffic on my Mikrotik router. I have a list of all the ports necessary for facetime connection but I still can’t figure out where I’m going wrong.
Can someone share the syntax for opening the ports kindly?
Hi Donalds.
Thanks for the reply.
The links you shared are for forwarding a port to a single IP on the network. I, however, am for a solution to allow all my internal users to access say port 5223 which is used for Facetime connections.
Any idea on how to achieve this?
I’m really surprised you can’t do this already. Facetime calls are initiated through an Apple login so inbound connection should effectively be either established or related and not need a specific rule setting up. In addition to this I have never needed to add a rule for any of the routers I have set up for family or the 500+ that have used my config script through work.
Can you do a
/export hide-sensitive
And share your set up?
Hi Steveocee.
The configuration is a below. Thanks for the assistance.
[admin@Homerouter] > /export
compact –
file – File name
hide-sensitive –
verbose –
[admin@Homerouter] > /export hide-sensitive
may/09/2018 14:00:28 by RouterOS 6.28
software id = XV4Z-GYE3
add name=bridge1
set [ find default-name=ether1 ] name=ether1-gateway
set [ find default-name=ether2 ] name=ether2-master-local
set [ find default-name=ether3 ] master-port=ether2-master-local name=
ether3-slave-local
set [ find default-name=ether4 ] master-port=ether2-master-local name=
ether4-slave-local
set [ find default-name=ether5 ] master-port=ether2-master-local name=
ether5-slave-local
/ip neighbor discovery
set ether1-gateway discover=no
add name=dhcp ranges=10.5.1.200-10.5.7.254
add address-pool=dhcp disabled=no interface=bridge1 lease-time=6h10m20s name=
default
add bridge=bridge1 interface=ether2-master-local
add address=10.5.1.1/21 comment=“default configuration” interface=
ether2-master-local network=10.5.0.0
add address=x.x.x.x/30 interface=ether1-gateway network=x.x.x.x
/ip dhcp-client
add comment=“default configuration” dhcp-options=hostname,clientid interface=
ether1-gateway
/ip dhcp-server config
set store-leases-disk=never
add address=10.5.0.0/21 comment=“default configuration” gateway=10.5.1.1
netmask=21
set allow-remote-requests=yes servers=8.8.8.8
/ip dns static
add address=10.5.1.1 name=router
add chain=forward comment=“default configuration” connection-state=
established,related
add chain=forward comment=“default configuration” connection-state=invalid
add chain=input protocol=icmp
add chain=input dst-port=5223 protocol=tcp
add chain=input connection-state=established
add action=masquerade chain=srcnat comment=“default configuration”
out-interface=ether1-gateway
add action=dst-nat chain=dstnat comment=“Port 110” dst-port=110 in-interface=
ether1-gateway protocol=tcp to-addresses=10.5.1.31 to-ports=110
add action=dst-nat chain=dstnat comment=“Port 25” dst-port=25 in-interface=
ether1-gateway protocol=tcp to-addresses=10.5.1.31 to-ports=25
add action=dst-nat chain=dstnat comment=“Webmail Mdaemon” dst-port=3000
in-interface=ether1-gateway protocol=tcp to-addresses=10.5.1.31 to-ports=
3000
add action=dst-nat chain=dstnat comment=“Mdeamon Remote Administration”
dst-port=444 in-interface=ether1-gateway protocol=tcp to-addresses=
10.5.1.31 to-ports=444
add action=dst-nat chain=dstnat dst-port=3389 in-interface=ether1-gateway
protocol=tcp to-addresses=10.5.1.31 to-ports=3389
add chain=srcnat
add distance=1 gateway=x.x.x.x
/ip service
set telnet disabled=yes
set www-ssl disabled=no
/romon port
add disabled=no
/system clock
set time-zone-name=Africa/Nairobi
/system identity
set name=Homerouter
/tool mac-server
add interface=ether2-master-local
/tool mac-server mac-winbox
Try changing your
Over into the forward chain.
add chain=forward dst-port=5223 protocol=tcp
Update:
I ended up disabling the firewall.
# may/09/2018 14:00:28 by RouterOS 6.28
/ip service
Please update you router to at least 6.40.8 (via System packages), reset configuration and re-run quickset to update dhcp pool and get a decent firewall rule set (with fasttrack).
Your router is currently vulnerable for dns amplification attacks and www-exploit, with or without firewall enabled (your firewall configuration is missing default drop policy).
Facetime should work out-of-the box without any firewall exemptions (except that outbound traffic in forward chain is allowed).
