Allowing only specific clients on Virtual WiFi ?
Hello.
I have a Virtual WiFi which is using old type encryption (WPA) since i am connecting to it some micro controllers, and i wish to allow only specific ones to connect to it.
( i have the MAC addresses of the controllers )
Under /interface wireless access-list add rules something like this:
add interface=<Virtual WiFi> mac-address=XX:XX:XX:XX:XX:XX action=accept
add interface=<Virtual WiFi> mac-address=YY:YY:YY:YY:YY:YY action=accept
add interface=<Virtual WiFi> action=reject
Rule order does matter, so make sure the reject rule comes after all the accept rules.
Ohhh.. I see now. Tank You mkx !
btw.. is there some what these MAC addresses to be in some list ?
No, each /interface wireless access-list row can only refer to a single MAC address.
If you switch to CAPsMAN, the /capsman access-list rows can match on MAC address prefixes (such as 98:03:00:00:00:00:00/FF:FF:00:00:00:00), but switching to CAPsMAN for this sole reason doesn’t seem worth it to me.
I see.. Well.. the one-by-one is then.
Thank You sindy ! :slight_smile:
