allowing sending and receiving mail throught walled garden.
Hi
I want my users to be able to check their mail withi=out logging in through the hotspot manager. Do i use the walled garden? An if not what do i do?? :slight_smile:
yes.
ip hotspot walled-garden> add dst-host=mailserver.com
Thanks for the help!
does it make a difference if the dst-host id a ip
β€œdst-host=192.168.10.101”
the dst-host is the name of the server you are connecting to. We had trouble getting the walled garden working with ip hosts. you should use a domain and make sure you set the dns servers in the MT.
I think the walled garden will work for web traffic only. if you want to use POP3 then you need to change some firewall rules.
