allowing Specific Sites on mikrotik . with Team Viewer
I’ve allowed only specific sites through Mikrotik with site IP’s ,Its working fine but now i want to allow team viewer access for user
. i m getting problem in it
As per Team.Viewer statement:
Which ports are used by TeamViewer?
In general, TeamViewer will always work if surfing on the Internet is possible. Hence, no firewall configuration is required. As an alternative to port 80 HTTP, port 443 HTTPs is also being checked. In addition, it is also possible to open only port 5938 TCP on the outgoing side. Data traffic should then be able to pass through on this port without any problems.
