Alphabetize?
Alphabetical listing of Type of Device, Parents etc… It would help. For example when you add a device and are assigning a type, you have to sift through all the possible devices. And if you have 100s of devices… In addition when you choose its dependencies [Parents], and if you have 1000s to choose from, it takes awhile if they are not alphabetized. Also on the right hand side the Network Maps are not alphabetized.
Using latest Beta version.
It would also be good on the Parent List to have the option to filter to the current map.
The same could be said when generating graphs, the ability to filter to a map or type of device…
This would make life easier.. We now have 3600 ish devices monitored using The Dude.. :slight_smile:
Regards
Lee
