Alternative 100% CPU usage on RB133
Hy all,
i have a strange thing with ROS 3.0rcx (3.0rc8 already in testing: same thing) on all RB133 which i’ve tested.
If i give a look on /system resource, i can see a strange CPU 100% usage.
Actually, thre’s no load on that RB133, but i can see 1%-100%-3%-1%-100%-1%-100% and so on, at 1sec interval.
With the same board, but with ROS 2.9.4x, i can see 1%-2%-5%-2%-3%-1% and so on, at 1sec interval.
Someone know why this happens?
this is normal operation of the router, you don’t need to worry about it.
Mmmmhh…really? I think i can trust you if you said that… :wink:
Ok, thanks Uldis, bye!
Thanks,
Seems a bit strange to me, and It is a bit of a concern as I load up my AP’s… It also seems to make the down loads a tad choppy but that could just be me.
Erik
