Alternative for RB711UA-2HnD
Hey Guy,
i’m looking for a RB to build a AP-Setup.
The RB711UA-2HnD would perfectly meet my requirements: 2.4 Ghz + dual chain + routeros (for sure ) + outdoor cases available ( 3rd party ). Unfortunately it’s no longer supported/manufactured by mikrotik.
Have someone a good recommendation as an alternative system?
Julian
Wait for future product - http://www.technotrade.com.ua/userfiles/files/rb912_outdoor_spec.pdf
RB912UAG-2HPnD
Why wait?
I think → with enclosure (outdoor). Is still not on market
If you have your own enclosure, then you can use http://routerboard.com/RB912UAG-2HPnD
So far I’ve not seen any outdoor enclosures for the 911 or 912 Board. The RB912 outdoor looks nice i’m wondering when it will be available on the marked.
RB911 is same in size ar RB711, so any RB711 enclosures should also fit RB911
Thanks for that information, i will check whether it fits. But if size and holes for screw a the same a see no problem.
yes, size and hole locations are identical
