Hello
I have a router with 2 wan interfaces (pppoe and static IP) with the settings below.
I want to be able to enter the router from the outside in case some wan interface falls. I’ve got it to work but I don’t understand something:
Why if pppoe client is disabled I need to add line [2] (below) in /ip route?
Are not all connections that enter through ether1 marked and only the route with the WAN-K2-FO mark is used? Is it possible to work without adding that line [2]?
add address=192.168.1.100/24 interface=ether1 network=192.168.1.0
/interface pppoe-client
add add-default-route=yes interface=wlan1-gateway keepalive-timeout=60 max-mru=1480 max-mtu=1480 name=pppoe-out1 password=password use-peer-dns=yes user=K2
/ip firewall mangle
add action=mark-routing chain=prerouting disabled=yes in-interface=pppoe-out1 new-routing-mark=nex passthrough=yes
add action=mark-routing chain=prerouting connection-mark=WAN-K2-FO new-routing-mark=WAN-K2-FO passthrough=no
add action=mark-connection chain=input connection-mark=no-mark in-interface=ether1 new-connection-mark=WAN-K2-FO passthrough=no
add action=mark-routing chain=output connection-mark=WAN-K2-FO new-routing-mark=WAN-K2-FO passthrough=no
add action=masquerade chain=srcnat comment="defconf: masquerade" out-interface=pppoe-out1
add action=src-nat chain=srcnat comment=K2-FO connection-mark=WAN-K2-FO out-interface=ether1 to-addresses=192.168.1.100
add action=masquerade chain=srcnat comment="K2-FO-from T" out-interface=ether1
add action=dst-nat chain=dstnat comment="To M" dst-port=9002 in-interface=pppoe-out1 protocol=tcp to-addresses=192.168.1.1 to-ports=80
[1] add distance=1 gateway=192.168.1.1 routing-mark=WAN-K2-FO
[2] add distance=1 gateway=192.168.1.1
/ip settings
set rp-filter=loose tcp-syncookies=yes
Thank you.
