Am I going nuts?
Ok, so this is my first MikroTik product, and my first exposure to RouterOS or it’s web interface, but I’m having a wierd issue.
I just received my MikroTik CRS125-24G-1S-IN today. I booted it up and it’s running RouterOS 6.6, so I upgraded to 6.27.
The first time it came up after that, everything was great, it was set up for routing, DHCP on the WAN interface, and had the DHCP and NAT set on the LAN interface.
I messed with it a bit, then hit “Reset Configuration” from the System menu to reset it to the factory configuration, but it would never ping or bring the web interface up after that. I let it sit for a good 10 minutes, nothing. So, I used the reset button and reset to factory default. The next time in, the WAN interface came up as static, and the DHCP and NAT were unchecked for the LAN interface.
So, I set DHCP and NAT on and set a dhcp range, hit apply config, then reloaded the page. NAT was set, but DHCP was unchecked again.
Some more messing around, then “Reset Configuration” again, and again, it won’t come up. Factory reset, and the same thing. Static on WAN, NAT and DHCP off.
I tried a few more times, and sure enough, whenever I hit “Reset Configuration” it will never come back up, and I end up having to factory reset with a paperclip.
So, I reset the config, came up to the main page, and simply set the WAN interface from STATIC to DHCP then hit Apply Config. Same thing, stops pinging and wont’ come back.
Is this just me, do I have a bad unit, is this a known problem with MikroTik, or with 6.27?
Any insight would be greatly appreciated.
Thanks.
Doc
Seems to be correct. When you reset configuration with no defaults (remove the config) it is without any settings so it cannot provide to you Web interface as it doesn’t have any ip. In this case use mac address for connection to the device to be able to set it. Use winbox discovery button to search for it.
Sorry, I accidentally double-posted before I realized that my first post required admin approval.
Please see this thread:
http://forum.mikrotik.com/t/am-i-going-nuts/85403/3
Thanks!
Doc
