am i under attack??
what is this ???
am i under attack??
it’s from my log file:
"may/19 01:15:10 system,error,critical login failure for user root from 116.10.191.227 via ssh "
Yes. Just logging tryouts. How many per minute are they?
what is logging tryouts??
in log file i get this msg a lot but not all times,
when i write this post there was a lot msgs (maybe 100)
and i got this on google:
We’re sorry…
… but your computer or network may be sending automated queries. To protect our users, we can’t process your request right now.
See Google Help for more information.
As @jarda eplained, they are just attempts to log in on to your router. I shouldn’t be very concerned as long as you change the default user and the password. But if you want, you can add this to your firewall:
http://wiki.mikrotik.com/wiki/Bruteforce_login_prevention
I eliminate a lot of these by simply turning off the access methods im not going to use.
In IP - > services. If you dont use ssh and are winbox only like me you can turn off everything except winbox. easy-peazy.
