Amazon Echo Dot losing connection
I have an Amazon Echo Dot that’s frequently losing connection to a hAP AC Access Point. The logs indicate that the Echo is de-authenticating.
This is occuring on 2.4 and 5Ghz. The Dot is in the the room next to the the AP, so I don’t think it’s a signal issue-
Wireless settings below-
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n bridge-mode=disabled channel-width=20/40mhz-Ce country="united kingdom" disabled=no distance=indoors frequency-mode=\
    regulatory-domain mode=ap-bridge mtu=1600 name=ALPHA-2.4Ghz security-profile=ALPHA-2.4Ghz ssid=ALPHA-2.4Ghz wireless-protocol=802.11 wmm-support=enabled
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=20/40mhz-Ce country="united kingdom" disabled=no distance=indoors frequency-mode=regulatory-domain mode=\
    ap-bridge mtu=1600 name=ALPHA-5Ghz security-profile=ALPHA-5Ghz ssid=ALPHA-5Ghz wireless-protocol=802.11
add disabled=no mac-address=6E:3B:6B:27:B2:F1 master-interface=ALPHA-2.4Ghz mode=ap-bridge mtu=1600 name=BETA-2.4Ghz security-profile=BETA-2.4Ghz ssid=BETA-2.4Ghz
add disabled=no mac-address=6E:3B:6B:27:B2:F0 master-interface=ALPHA-5Ghz mode=ap-bridge mtu=1600 multicast-helper=full name=BETA-5Ghz security-profile=BETA-5Ghz ssid=\
    BETA-5Ghz
add mac-address=6E:3B:6B:27:B2:F2 master-interface=ALPHA-2.4Ghz mode=ap-bridge mtu=1600 name=GAMMA-2.4Ghz security-profile=GAMMA-2.4Ghz ssid=GAMMA-2.4Ghz
add mac-address=6E:3B:6B:27:B2:F4 master-interface=ALPHA-5Ghz mode=ap-bridge mtu=1600 name=GAMMA-5Ghz security-profile=GAMMA-5Ghz ssid=GAMMA-5Ghz
add disabled=no mac-address=6E:3B:6B:27:B2:F3 master-interface=ALPHA-2.4Ghz mode=ap-bridge mtu=1600 name=OMEGA-2.4Ghz security-profile=OMEGA-2.4Ghz ssid=OMEGA-2.4Ghz
add disabled=no mac-address=6E:3B:6B:27:B2:F5 master-interface=ALPHA-5Ghz mode=ap-bridge mtu=1600 name=OMEGA-5Ghz security-profile=OMEGA-5Ghz ssid=OMEGA-5Ghz
Is anyone using an Amazon Echo Dot with a Mikrotik AP, or does anyone have any suggestions?
A user on reddit suggested increasing the DHCP lease time, and it looks like the issue is now resolved.
It was set to 1 minute (!) due to some previous testing and Id forgot to set it back.
