Amazon Prime Video borked on Shield and Chromecast
So this problem is limited to the Shield Pro and Chromecast dongle. With the HexS as my router, most everything on the network is fine except for a few apps on the Shield Pro (and Chromecast Dongle).
Amazon Prime Video first gives a multilingual error message, then loads the interface, but will not stream any video.
Netflix and Disney+ work, but verrrry slowly.
The apps work fine on PCs and on LG WebOS (older version).
(It also breaks the functionality of the Weather Underground app on my Samsung phone).
I have none of these problems with several non-Mikrotik routers, but would like to use the HexS as it seems more stable long term (?)
Tried several things including adjusting the IP6 MTU, and resetting the configuration to default, just getting the internet to work and using the Xfinity DNS instead of Pihole/unbound, but the problem is the same.
Any ideas, and what config files would help?
