If i have a mikrotik router can i hide him from network and only if you knew the ip you will enter???
Yes. In firewall deny icmp, also you can in firewall only allow the ip you are logging in from. Not perfect but most user’s wont go any further.
maybe at first you should disable Neighbour Discovery sending in Ip - Neighbours? =)
